After reading a post on the hardware development board about the crosshatch ground plate pattern on the arduino board, I took a close look at my new arduino board, yikes, a solder blob is shorting two pins on the USB/serial chip. My older board is fine without this blob. Should it be removed? I don't know if I will simple mess it up trying.
I think others have posted on the same issue. It's not a problem as those two pins are wired to ground anyway. Probably a production thing to make up for a missing jumper or trace?
Lefty
yes others have expressed concern, but both pins goto ground, so its ok, and is on all official style boards as of recently
retrolefty,
Thanks for a quick reply. The blob makes sense now as the pin 25 and 26 are both supposed to be grounded. No wonder nothing bad has happened to my board yet. ;D
