Solder Station
Hi guys i am stuck on a project i am wandering if you can help me i am working on a soldering station with i want to used buttons up button down button and a start or ok button but i just don't know how to write the program
can you help me thanks
Look at the examples that come with the IDE :wink: The state change example is probably the most suitable.
You need a variable that will be incremented when you push the UP button and will be decremented when you push the DOWN button. You will also need a variable that will be set when you push the OK button (e.g. to store the selected temperature if that is what it does).
Try something, if it does not work, post your code and you can get advise.
