soldering fault on FTDI chip connection?
Hello everyone,
I've had my arduino diecimila now for about two weeks and used it without any problems. However I detected a tiny solder trace between pin 30 and 31 (test and agnd) of the FTDI chip. The pins of the chip are very tiny, as is the room between them. I can clearly see the solder between the pins with a loupe.
So I have two questions:
1.) Is this a problem, or is this normal? 2) If this is a problem what can I do about it?
With kind regards,
John
All good!
http://www.ladyada.net/forums/viewtopic.php?f=22&p=35801
Perfect thanks for the quick response,
For anyone who views this post in the future a small correction I should have mentioned pin 25 (agnd) and 26 (test) and not 31 and 30 that don't even exist.
John
