And I'm assuming what he did was solder pins onto the motor shield board? Would it be basically adding pins into the holes of the motor shield for A4 & A5 and then "connecting" the holes with pins to the already-soldered pins on the edge of the shield labeled A4 & A5 like in my drawing?
How can you tell? It does kinda seems like he used A3 & 4 instead but the picture is so dark.
I just looked at the next to last picture and it does look like A4 & 5.
But my question is how did he connect the pins he soldered onto the shield, which are kind of on the inside of the shield, with the A pins which are on the edge of the shield?
It looks like 4 and 5 to me in photo? The tip of pin 3 is obscured by the housing of the jumper on A4 - note that there's no pin for A5 visible in front of the two connectors.
Can you verify if that's the case ? Are there traces going to those pads labeled A0 - A5 ?
IF you were going to use ONE of those "A" lines, the OTHER wire should go to GND , NOT to the "Ax" pad next to the one you are using. If you were using TWO "Ax" pins then there should be TWO GND wires going to the GND bus.
I would avoid the Instructables that don't include schematics (which is probably most of them).
Did you look at the schematic I linked for the motor shield ? Do you understand the functions of those pins on that row of pads. (the pins I listed in my last post) ?
Do you know what IOREF is ? (not sure how this is used)
What about SNS0 , SNS1 ? (these are obvious)
Did you see the 3-pin connectors IN2 & IN3 and OUT5 & OUT6 ? (not so clear as to their purpose)
If you know where those signals you can easily confirm that they are connected to that row of solder pads.
Do you see the connection between the signals above and that row of pads ?
I just saw this...I know its terrible but its precisely what I want to avoid.
As you can see, this guy actually soldered header pins directly onto the motor shield's A0-A5 or at least thats what it looks like.
What Im suggesting is to use the holes that are right next to those A0-A5 pins, of which I can see 3 rows:
5V row of 6 holes
GND row of 6 holes
unlabeled row of 6 holes
to connect a stack of header pins onto and then connect the corresponding A4 & A5 pins to Echo and Trig.
But what is still not clear to me is whether I would need to make a connection between the holes in the unlabeled row of holes and the actual A0-A5 pins on the very edge, or if those connections are somehow already made in the shield.
The reason I ask is that it seems to me they might be internally connected somehow.
Are those holes in any of the 3 rows mentioned above internally connected to anything already? Why is the top row labeled 5V and the middle row labeled GND if they are not connected to anything?
Thanks raschemmel...for not giving me the answer. I did as you suggested, which I really should have thought of before, and indeed they are connected. I went ahead and tested the 5v-GND rows as well for voltage and theyre right on the money.
