Not sure if this is the correct section for this post, but...
Does anyone have any advice for soldering the power-on-ethernet board onto an Arduino Ethernet board? I bought these 2 boards , assuming that the POE board just plugged into the main Arduino Ethernet board, but there's no socket, so it will need soldering (the place I bought it from didn't list them as a pre-constructed set). There are some very small components near the holes for the POE board - am I going to be OK soldering it in with a normal (smallish) soldering iron? Does it need to be soldered on both sides or are the holes through-plated (they look like they are)? I assume I'd insert the POE board and then solder it from the underside (because the existing components are on the top)?
Thanks!
