Soldering/Wirering question
Dear Arduino-Community!
I have a question regarding soldering/wiring my first complex arduino project for standalone use.
  1. Is there any difference in soldering the two scenarios electronicly?
  2. Is this the same when its not GND but Vcc?
Because using the left approach will reduce the hassle with all the wires underneath my board. Is it possible to solder that way?
There is no difference; either version works. Also there's no difference when connecting it to VCC or any other voltage whatsoever.
All points in a connected line are at the same potential (which is the important factor for a voltage).
Thank you very much! :)
That is not strictly true. It depends on the amount of current being carried and also on what the two grounds on the IC actually are. If the further ground has large currents flowing then the left hand circuit can cause "ground bounce". If the two grounds are analogue and digital grounds then for less noise in the circuit you are better off using the right hand circuit and having a "star ground" configuration.
However for general purpose use the left hand circuit is fine.
@Grumpy_Mike: That is true. Also if those connections are too long we’d have some noise from electromagnetic induction and of course a slight decrease in the potential (and therefore the voltage).
But I guess we’re talking about an ordinary and small circuit for an electronics starter and therefore it doesn’t matter; either way works!
Mostly, it makes no difference; but there are exceptions, for example:
  • if one of the ground or VCC pins is carrying high currents that are being switched rapidly (e.g. PWMing a motor or a lot of LEDs)
  • if one of the grounds is the Agnd or Avcc pin of an atmega328 or similar chip
In these cases, the varying current flow to/from one of the pins can induce enough voltage in the common wire to affect the other one.
