Solenoid sequence timer expansion troubles.
Hello, I had a friend build and program a timing device that I use to activate 12vdc solenoids, etc through the UNO. It was originally built with four outputs. I have expanded to 7 op's. Six are controlled with potentiometers to set the delays, the 7th is connected only to the digital OP. I am hoping to control the 7th through code, delay and duration. The code info is here: https://www.dropbox.com/sh/ra11kycj8uexa4d/gVs0RCkZYZ?m A schematic is here: http://www.flickr.com/photos/longshotsphoto/8869802246/ I can only get just so far, then I have to consult the experts. I can't reach the originator =( Anyone got advice? :disappointed_relieved:
I can only get just so far, then I have to consult the experts. I can't reach the originator smiley-cry Anyone got advice?
Yes. Generally, when you consult an expert, you say something like "I need help with xxxx", not "I need help".
So, what is it you need help with?
