Solenoid valve doesn’t work
This is the setup that i used. This is a DC 3.6V solenoid valve, but in the product review, they said it operates at 4.5-6V, so i have tried to increase the supply voltage.
However, it still didn’t work.
Code: i simply turned on and off the relay with Serial Monitor
If you power the valve directly, does it work?
You mean plug the power supply directly to the valve? I haven’t tried it
can you explain what we see here and what we don't see on the back of the green screw terminal
I guess you have a flyback diode between + and - and that the red cable at the back goes to the + of your power supply (what is it?) and that the second black cable that you have in the front goes to the negative pole of the power supply ?
how much current can your solenoid valve draw ?
Yes it is the flyback diode. Red wire of the solenoid valve connects to NO of the relay.
Positive terminal of power supply goes to COM
Black wire of the solenoid connects to negative terminal of the power supply
The current draw is not known as there’s no details about that. I tried to increase the current step by step
Those solenoid valves often need just a quick pulse to open. And reverse polarity to close. In that case your relay setup will not work.
Try it just with your power source, without diode, swapping polarities.
Don't keep it powered, just a quick pulse.
I haven’t tried to connect directly, but i have tried to switch polarity, and it didn’t work
I will try to connect directly
without diode!
May i ask why is that so
When you change polarity you short the circuit if you have that diode on board.
Also, to operate the solenoid it takes less than a second. If you keep it powered, you might burn it. Also you need quite high current.
Oh my god i forgot about that. I left the diode on, not sure if my valve was damaged
