solenoid valve
does it matter what way I apply current to a solenoid valve? There is no plus or minus on either of the terminals. They look the same
No.
Trrn13P:
Unless there is something special about the solenoid, it is just a coil of wire that makes an electromagnet when current is applied. The iron center responds to either pole of magnetism, so it make no difference to it which pole if which.
Try it!!
Paul
Thanks
Remember to add a flyback diode to your solenoid if you want to have the connected electronics survive switching it off.
