I am looking for a variable solenoid valve. I have worked with a normal on/off solenoid valve and a relay but I couldn't find a variable one which opens or closes proportionally with the power provided.
I was basically looking to control the flow of my filter for my fish tank as it causes it to overflow if I don't adjust the valves correctly so I was thinking that it would be best if I could get a variable one which doesn't turn on and off continuously to maintain the level of the water.
Solenoid valves are not suitable for proportional control. You need a gate valve operated by a servo. Off the shelf ones would probably be expensive so might have to make your own using a manual valve mechanically linked to a suitable servo.
The advanced ProControl™ Servoid Series delivers extremely precise control and high output flow settings, and has become a standard in critical care patient ventilation equipment.
If you don't adjust the proportional valve correctly it will still overflow.
So exactly how were you planning to correctly adjust the proportional valve?
I am trying to find how to proportionally control this motor which is rated 220V by using a relay, I was thinking about using the normal relay but there is this system in my house that the water levels can vary in the tank, so what I wanted was a variable relay which could be used with the motor to control the motor's output.
I moved your topic to an appropriate forum category @shuta_jin.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Your two or more topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
