Solid green light on Portenta H7 lite after firmware upload
What does a solid green light mean on the portenta after firmware upload? I have a rather large piece of firmware which if I upload using my laptop works fine. I have it deployed along with a nvidia jetson and when i flash the firmware using that I get a solid green light on the portenta and the port is not detected anymore so I can't tell if the firmware is working anymore or not. To be able to flash the portenta again I need to use my laptop and double press the reset button to put it to bootloader mode and upload a dummy program from the arduino ide, it doesn't work using platformio anymore (shows broken pipe). Once that is done I can upload my regular firmware using pio.
The code on both the devices is the same as I am using git to ensure that.
I am using platformio. The version of platformio is the same on my laptop and the Jetson.
