Hello. First time poster. Long time lurker. Thanks for reading. Have always been able to find what I'm after for the most part until now.
I have a sketch with 16 addressable leds. I have some lights flashing, however, I don't want them all to flash and would like some solid and not effected by the delay.
How may I achieve this? Thanks for your time and insight.
LarryD
October 2, 2023, 6:39pm
2
Welcome.
We need more information so we can help you.
Show us your attempt.
Always show us a good schematic of your proposed circuit.
Show us good images of your ‘actual’ wiring.
Give links to components.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch .
Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
Thank you for the welcome.
I have not attempted this because I'm am almost uncertain of how to acheive it
#include <FastLED.h>
#define NUM_LEDS 16
#define DATA_PIN 5
#define COLOR_ORDER GRB
#define CHIPSET WS2812
#define BRIGHTNESS 5
#define VOLTS 5
#define MAX_AMPS 500
CRGB leds[NUM_LEDS];
FastLED.addLeds<CHIPSET, DATA_PIN, COLOR_ORDER>(leds,NUM_LEDS);
FastLED.setMaxPowerInVoltsAndMilliamps(VOLTS, MAX_AMPS);
FastLED.setBrightness(BRIGHTNESS);
FastLED.clear();
FastLED.show();
//Left Meter
leds[4] = CRGB::Purple;
leds[5] = CRGB::Aqua;
leds[6] = CRGB::Aqua;
leds[7] = CRGB::Aqua;
leds[8] = CRGB::Aqua;
leds[9] = CRGB(254, 80, 0);
leds[10] = CRGB(254, 80, 0);
leds[11] = CRGB(254, 80, 0);
FastLED.show();
FastLED.clear();
delay(70);
leds[4] = CRGB::Black;
leds[5] = CRGB::Black;
leds[6] = CRGB::Black;
leds[7] = CRGB::Black;
leds[8] = CRGB::Black;
leds[9] = CRGB(0, 0, 0);
leds[10] = CRGB(0, 0, 0);
leds[11] = CRGB(0, 0, 0);
FastLED.show();
FastLED.clear();
delay(60);
//Right Meter
leds[0] = CRGB::Aqua;
leds[1] = CRGB::Aqua;
leds[2] = CRGB::Aqua;
leds[3] = CRGB::Purple;
leds[15] = CRGB::Aqua;
leds[14] = CRGB(254, 80, 0);
leds[13] = CRGB(254, 80, 0);
leds[12] = CRGB(254, 80, 0);
FastLED.show();
FastLED.clear();
delay(70);
leds[0] = CRGB::Black;
leds[1] = CRGB::Black;
leds[2] = CRGB::Black;
leds[3] = CRGB::Black;
leds[15] = CRGB::Black;
leds[14] = CRGB(0, 0, 0);
leds[13] = CRGB(0, 0, 0);
leds[12] = CRGB(0, 0, 0);
FastLED.show();
FastLED.clear();
delay(60);
Here is my code, I certainly hope I did this right, so please forgive the ignorance if not so.
I just can't wrap my brain on how to keep the purple lights on while the others do their thing. Maybe I'm just not wording it right when I search. So, any help on this is greatly appreciated. Thanks again.
LarryD
October 2, 2023, 7:10pm
4
FastLED.show();
FastLED.clear();
What do you think happens above ?
The process should be set the colour of each pixel before you call show .
kolaha
October 2, 2023, 7:38pm
5
#define NUM_LEDS 16
#define DATA_PIN 5
#define CHIPSET WS2812b
#define VOLTS 5
FastLED.addLeds<CHIPSET, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS);
fill_solid(leds, NUM_LEDS, CRGB::Aqua);
static uint32_t prevMills = 0;
const uint16_t period = 1000;
static bool state = false;
if (millis() - prevMills >= period) {
prevMills += period;
state = (prevMills / 1000) % 2;
for (byte i = 0; i < NUM_LEDS; i += 4) {
if (state)leds[i] = CRGB::DarkOrange;
else leds[i] = CRGB::Black;
FastLED.show();
Thanks for your response, however, this didn't achieve the effect I was after.
Aren't they set to their color, before the show command?
LarryD
October 2, 2023, 8:01pm
8
“ The process should be set the colour of each pixel before you call show .”
These agree with each other.
What do you think happens below ?
FastLED.show();
FastLED.clear();
The brightness value 5 in the row " #define BRIGHTNESS 5 " is very low.
Try running your code with a value in the order of 100 or even more.
See the simulation.
"PiscaPisca.ino - Wokwi ESP32, STM32, Arduino Simulator
What effect do you want to achieve with your code?
kolaha
October 2, 2023, 8:13pm
10
of course not. you use it for learning and make effect you was after by yourself. here is not a wish fulfillment service.
system
Closed
March 30, 2024, 8:13pm
11
