I checked several SSR DC-DC offers and found only one that honestly claims to work with DC output and I/O isolation. Also check the data sheet for circuit isolation voltage.
Right, DC output and I/O isolation requires a special circuit at low demand. 30$ seems to be a reasonable price.
These optocouplers look interesting, and they seem allot more cost effective. Cannot find one that handles more than 100mA on the Output/Collector side
ohhh ok that makes sense! thanks for your help, will try those SSRs then given I can do it in a single component and I'm trying keep things minimal to a degree..
I have box of SSRs. About 1/3 are DC. The rest are AC. The DC units are simply a MOSFET driven by a transistor to keep the logic right side up. All came from a commercial reflow oven. All are plug-in design.
Paul
How do you mean isolated only for the AC ones? I mean if its not isolated does that defy the point of an SSR being contactless witching betweem Input and Putput through an LED?
So just confirming, will this work for my requirements: Model: G3VM-41AY1
The DC SSRs that I have share a ground for both input and output. Simple MOSFET driven by a transistor. The AC SSRs have separate connections for the LED and the AC side.
