Hello everyone.
I m looking fo a solid state relay which works with pulses and push button (not switch). 1 pulse, releay on, another pulse, relay off. Any suggestions ?
relay must hadle 4A max
power source : 7.4 - 12V.
thanks
Hello everyone.
thanks
You can use a flip-flop, like the 4013 for example.
Just tie S and R to ground, connect Q-inverse to D and send your on-off pulses to the clock pin. Then connect the Q output to the input of an SSR.
Pieter
Thanks Pieter
I was hoping for something "ready to go", like a solid state relay with pulses. However if there is nothing else I will try what you said, but as I m new, where can i find a diagram ?
Figure 9 in the datasheet.
The first chip is just a Schmitt trigger to prevent retriggering when the input voltage fluctuates around the threshold.
Pieter
