Solucion de error al utilizar un DualVNH5019MotorShield
Hola, disculpen al momento de programar un arduino utilizando DualVNH5019MotorShield tengo varios errores con "‘DualVNH5019MotorShield’ does not name a type.
Alguien podría ayudarme por favor. estoy usando esto.
#include <DualVNH5019MotorShieldMod3.h>
DualVNH5019MotorShield md;
#include <Servo.h>
Servo myservo;
char dataIn=‘S’;
char determinant;
char det;
int vel = 200; //Bluetooth Stuff
int overdrive = 13; //Press Toggle Switch #1, the pin13 LED will light up
void setup(){
Serial.begin(9600);md.init();
myservo.attach(6);delay(100);
myservo.write(90);delay(100);
void loop(){ det = check(); // You’ll need to reconstruct this if your not using the Pololu Dual VNH5019
while (det == ‘F’) // F, move forward
{md.setSpeeds(vel,vel);det = check();}
while (det == ‘B’) // B, move back
{md.setSpeeds(-vel,-vel);det = check();}
while (det == ‘L’) // L, move wheels left
{md.setSpeeds(-vel,vel);det = check();}
while (det == ‘R’) // R, move wheels right
{md.setSpeeds(vel,-vel);det = check();}
while (det == ‘I’) // I, turn right forward
{md.setSpeeds(vel,vel/2);det = check();}
while (det == ‘J’) // J, turn right back
{md.setSpeeds(-vel,-vel/2);det = check();}
while (det == ‘G’) // G, turn left forward
{md.setSpeeds(vel/2,vel);det = check();}
while (det == ‘H’) // H, turn left back
{md.setSpeeds(-vel/2,-vel);det = check();}
while (det == ‘S’) // S, stop
{md.setSpeeds(0,0);det = check();}
//---------------------Toggle switch code------------------//
/*while (det == ‘W’){myservo.write(180);delay(100);det = check();}
while (det == ‘w’){myservo.write(90);delay(100);det = check();}
while (det == ‘U’){myservo.write(0);delay(100);det = check();}
while (det == ‘u’){myservo.write(90);delay(100);det = check();}
int check()
{if (Serial.available() > 0) {dataIn = Serial.read();
if (dataIn == ‘F’){determinant = ‘F’;}
else if (dataIn == ‘B’){determinant = ‘B’;}else if (dataIn == ‘L’){determinant = ‘L’;}
else if (dataIn == ‘R’){determinant = ‘R’;}else if (dataIn == ‘I’){determinant = ‘I’;}
else if (dataIn == ‘J’){determinant = ‘J’;}else if (dataIn == ‘G’){determinant = ‘G’;}
else if (dataIn == ‘H’){determinant = ‘H’;}else if (dataIn == ‘S’){determinant = ‘S’;}
else if (dataIn == ‘0’){vel = 400;}else if (dataIn == ‘1’){vel = 380;}
else if (dataIn == ‘2’){vel = 340;}else if (dataIn == ‘3’){vel = 320;}
else if (dataIn == ‘4’){vel = 280;}else if (dataIn == ‘5’){vel = 240;}
else if (dataIn == ‘6’){vel = 200;}else if (dataIn == ‘7’){vel = 160;}
else if (dataIn == ‘8’){vel = 120;}else if (dataIn == ‘9’){vel = 80;}
else if (dataIn == ‘q’){vel = 40;}
else if (dataIn == ‘U’){determinant = ‘U’;}else if (dataIn == ‘u’){determinant = ‘u’;}
else if (dataIn == ‘W’){determinant = ‘W’;}else if (dataIn == ‘w’){determinant = ‘w’;}
}return determinant;}
Hola @JossLuis351507, bienvenido al foro Arduino en Español. Te invito a que leas las normas del foro y en ellas encontrarás como se deben postear los códigos/errores. Así como lo has hecho esta mal presentado. Por favor, edita.
Dice que esto
no existe o que no existe el tipo DualVNH5019MotorShield
Como no has puesto un enlace a dicha librería mas no puedo decirte. He encontrado otra posible explicación, dice en el README
This library is designed to work with the Arduino IDE versions 1.6.x or later
Librería diseñada para trabajar con Arduino IDE versiones 1.6.x o anteriores. O posteriores como lo que estarás usando.
No dejes de editar tu post.
La expliación que creo puede haber es que tengas algo mal en la instalación de la librería porque acabo de comparar el ejemplo y tu código esta igual o parcialmente similar al demo.ino
