[solucionado] easyvr3 encender y apagar
hola chic@s, sigo con este proyecto, haber si me podeis guiar un poco, quiero accionar las luces con un mismo comando,cada vez que dica “luz cocina” me cambie el estado del led.
haber que podeis hacer, un saludo y muchas gracias
#include "Arduino.h"
#if !defined(SERIAL_PORT_MONITOR)
 #error "Arduino version not supported. Please update your IDE to the latest version."
#endif
#if defined(SERIAL_PORT_USBVIRTUAL)
 // Shield Jumper on HW (for Leonardo and Due)
 #define port SERIAL_PORT_HARDWARE
 #define pcSerial SERIAL_PORT_USBVIRTUAL
#else
 // Shield Jumper on SW (using pins 12/13 or 8/9 as RX/TX)
 #include "SoftwareSerial.h"
 SoftwareSerial port(12, 13);
 #define pcSerial SERIAL_PORT_MONITOR
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
 GROUP_0  = 0,
 GROUP_1  = 1,
 GROUP_2  = 2,
 GROUP_3  = 3,
 GROUP_4  = 4,
 GROUP_5  = 5,
enum Group0
 G0_KIWI = 0,
enum Group1
 G1_LUZ_DAVID = 0,
 G1_LUZ_RAKEL = 1,
 G1_MUSICA_DAVID = 2,
 G1_MUSICA_RAKEL = 3,
enum Group2
 G2_LUZ_BLANCA_DAVID = 0,
 G2_LUZ_CHILL_OUT_DAVID = 1,
 G2_LUZ_COCINA_DAVID = 2,
 G2_LUZ_COMEDOR_DAVID = 3,
 G2_LUZ_MATRIMONIO_DAVID = 4,
 G2_LUZ_NEREA_DAVID = 5,
 G2_MENU_DAVID = 6,
enum Group3
 G3_LUZ_BLANCA_RAKEL = 0,
 G3_LUZ_CHILL_OUT_RAKEL = 1,
 G3_LUZ_COCINA_RAKEL = 2,
 G3_LUZ_COMEDOR_RAKEL = 3,
 G3_LUZ_MATRIMONIO_RAKEL = 4,
 G3_LUZ_NEREA_RAKEL = 5,
 G3_MENU_RAKEL = 6,
enum Group4
 G4_PLAY = 0,
 G4_STOP = 1,
 G4_SIGUIENTE = 2,
 G4_MAS_ALTO = 3,
 G4_MAS_BAJO = 4,
 G4_MENU = 5,
enum Group5
 G5_PLAY = 0,
 G5_STOP = 1,
 G5_SIGUIENTE = 2,
 G5_MAS_VOLUMEN = 3,
 G5_MENOS_VOLUMEN = 4,
 G5_MENU = 5,
int8_t group, idx;
 // setup PC serial port
 pcSerial.begin(9600);
 // bridge mode?
 int mode = easyvr.bridgeRequested(pcSerial);
 switch (mode)
 case EasyVR::BRIDGE_NONE:
   // setup EasyVR serial port
   port.begin(9600);
   // run normally
   pcSerial.println(F("---"));
   pcSerial.println(F("Bridge not started!"));
 case EasyVR::BRIDGE_NORMAL:
   // setup EasyVR serial port (low speed)
   port.begin(9600);
   // soft-connect the two serial ports (PC and EasyVR)
   easyvr.bridgeLoop(pcSerial);
   // resume normally if aborted
   pcSerial.println(F("Bridge connection aborted!"));
 case EasyVR::BRIDGE_BOOT:
   // setup EasyVR serial port (high speed)
   port.begin(115200);
 while (!easyvr.detect())
   Serial.println("EasyVR not detected!");
 easyvr.setPinOutput(EasyVR::IO1, LOW);
 Serial.println("EasyVR detected!");
 easyvr.setTimeout(5);
 easyvr.setLanguage(4);
 group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
 if (easyvr.getID() < EasyVR::EASYVR3)
   easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
 Serial.print("Say a command in Group ");
 Serial.println(group);
 easyvr.recognizeCommand(group);
 do
   // can do some processing while waiting for a spoken command
 while (!easyvr.hasFinished());
   easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
 idx = easyvr.getWord();
 if (idx >= 0)
   // built-in trigger (ROBOT)
   // group = GROUP_X; <-- jump to another group X
   return;
 idx = easyvr.getCommand();
 if (idx >= 0)
   // print debug message
   uint8_t train = 0;
   char name[32];
   Serial.print("Command: ");
   Serial.print(idx);
   if (easyvr.dumpCommand(group, idx, name, train))
     Serial.print(" = ");
     Serial.println(name);
// beep
   easyvr.playSound(0, EasyVR::VOL_FULL);
   // perform some action
   action();
 else // errors or timeout
   if (easyvr.isTimeout())
     Serial.println("Timed out, try again...");
   int16_t err = easyvr.getError();
   if (err >= 0)
     Serial.print("Error ");
     Serial.println(err, HEX);
void action()
   switch (group)
   case GROUP_0:
     switch (idx)
     case G0_KIWI:
       // write your action code here
        group = GROUP_1; //<-- or jump to another group X for composite commands
   case GROUP_1:
     switch (idx)
     case G1_LUZ_DAVID:
     case G1_MUSICA_DAVID:
      group = GROUP_5;// <-- or jump to another group X for composite commands
   case GROUP_2:
     switch (idx)
     case G2_LUZ_BLANCA_DAVID:
     case G2_LUZ_CHILL_OUT_DAVID:
     case G2_LUZ_COCINA_DAVID:
      group = GROUP_1;// <-- or jump to another group X for composite commands
habia pensado en hacer algo asi, pero no se si es correcto,
int estado = 0;
 pinMode(3, OUTPUT);
case G2_LUZ_COCINA_DAVID: // le pido al easyvr que encienda o apague la luz
estado = digitalRead(3); // le pregunto como esta el led
if(estado == HIGH); // si esta encendido
digitalWrite(3,LOW); // apaga el led
else (
 digitalWrite(3,HIGH); // si no esta encendido , enciende
easyvr.playSound(0, EasyVR::VOL_FULL);// contesta con luz cocina
conseguido!!en resumido...
int blanca = 2;
 pinMode(2,OUTPUT);
void action()
case GROUP_2:
     switch (idx)
         digitalWrite(blanca, !digitalRead(blanca));
         easyvr.playSound(8, EasyVR::VOL_FULL);
         group = GROUP_2;
Bueno al final, lo has logrado tu mismo, felicitaciones!!
NOTA: Te doy la gracias por haber corregido los post y que se vean con etiquetas.
chic@s!!! os he dejado un tutorial completito en el apartado documentacion se llama "Easyvr3 Tutorial principiante". completamente desde 0, que programas y librerias necesitas, donde conseguirlos. y un paso a paso con fotografias para poner en marcha tu easyvr3.
espero que os guste!!
