Hola, te propongo esto, te paso un código (no es mio lo bajé de http://www.glacialwanderer.com/_blog/blog2008/04_April/sht15.pde) ponés los pines así (data pin -> 10 y clock pin -> 11) y te conectás con el monitor a 9600 baudios.
Tipeás "t" (sin comillas) y enter. Te devuelve la temperatura. Si hacés lo mismo con "h" en lugar de la t, te devuelve la humedad.
Si esto te funciona, revisamos lo que tenés hecho hasta ahora.
Acá va el código (bajado desde:http://www.glacialwanderer.com/_blog/blog2008/04_April/sht15.pde):
// Maurice Ribble
// 4-3-2008
// http://www.glacialwanderer.com/hobbyrobotics
// This code tests the SHT15 on the Arduino board.
// This app assumes your data pin is pin 10 and your your clock pin is pin 11.
// To run this app just attach HyperTerminal (or similar serial communications tool)
// to your Arduino board at 9600 bits per second. I also needed te set the
// flow control to none or I couldn't send commands to my Arduino board via HyperTerminal.
// Then press the 't' key to take a temperature reading or the 'h' key to take a
// humidity reading.
// These are commands we need to send to HSHT15 to control it
int gTempCmd = 0b00000011;
int gHumidCmd = 0b00000101;
int shiftIn(int dataPin, int clockPin, int numBits)
int ret = 0;
int i;
for (i=0; i<numBits; ++i)
digitalWrite(clockPin, HIGH);
delay(10); // I don't know why I need this, but without it I don't get my 8 lsb of temp
ret = ret*2 + digitalRead(dataPin);
digitalWrite(clockPin, LOW);
return(ret);
void sendCommandSHT(int command, int dataPin, int clockPin)
int ack;
// Transmission Start
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
digitalWrite(dataPin, HIGH);
digitalWrite(dataPin, LOW);
// The command (3 msb are address and must be 000, and last 5 bits are command)
shiftOut(dataPin, clockPin, MSBFIRST, command);
// Verify we get the coorect ack
pinMode(dataPin, INPUT);
ack = digitalRead(dataPin);
if (ack != LOW)
Serial.println("Ack Error 0");
if (ack != HIGH)
Serial.println("Ack Error 1");
void waitForResultSHT(int dataPin)
int i;
int ack;
for(i= 0; i < 100; ++i)
delay(10);
if (ack == LOW)
if (ack == HIGH)
Serial.println("Ack Error 2");
int getData16SHT(int dataPin, int clockPin)
int val;
// Get the most significant bits
val = shiftIn(dataPin, clockPin, 8);
val *= 256;
// Send the required ack
// Get the lest significant bits
val |= shiftIn(dataPin, clockPin, 8);
return val;
void skipCrcSHT(int dataPin, int clockPin)
// Skip acknowledge to end trans (no CRC)
Serial.begin(9600); // open serial
int theDataPin = 10;
int theClockPin = 11;
char cmd = 0;
int ack;
while (Serial.available() > 0)
cmd = Serial.read();
switch (cmd)
case 't': //Read Temperature
int val;
int temp;
sendCommandSHT(gTempCmd, theDataPin, theClockPin);
waitForResultSHT(theDataPin);
val = getData16SHT(theDataPin, theClockPin);
skipCrcSHT(theDataPin, theClockPin);
Serial.print("Temp is:");
Serial.print(val, HEX);
temp = -40.0 + 0.018 * (float)val;
Serial.print(" ");
Serial.println(temp, DEC);
case 'h': //Read Humidity
int val;
int humid;
sendCommandSHT(gHumidCmd, theDataPin, theClockPin);
Serial.print("Humidity is:");
humid = -4.0 + 0.0405 * val + -0.0000028 * val * val;
Serial.print(" ");
Serial.println(humid, DEC);
default:
Serial.println("You pressed something else");
