[SOLUTION] Arduino IDE not opening or flashing and disappearing
P.S: I have been looking for a solution to this problem for about a week now. Luckily for me. An idea popped in from the online research I did.
I hope this helps someone. If it did please comment. Thank you.
The cause of this problem of the Arduino IDE (whether for Intel Galileo or Arduino) not opening is a conflict between the 32- bit java installed in the Arduino IDE install directory
and the 32-bit java installed on your system.
To quickly solve this problem.
  1. Delete all the contents in the java directory of your Arduino installation location.
    e.g: "C:\arduino-1.5.3-Intel.1.0.4\java" or "C:\Program Files (x86)\Arduino\java"
  2. Copy the contents in the java directory of your system
e.g: For 32-bit systems- "C:\Program Files\Java\jre1.8.0_25"
For 64-bit systems- "C:\Program Files (x86)\Java\jre1.8.0_25"
  1. Paste the all the files you copied in step 2 above into the arduino java directory in step 1.
  2. Click on arduino.exe in the install diretory. The arduino IDE comes to life.
