Here ya go:
PS C:\Program Files\Arduino IDE> &".Arduino. IDE"
& : The term '.Arduino. IDE' is not recognized as the name of a cmdlet, function, script file, or operable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:2
+ &".Arduino. IDE"
+ CategoryInfo : ObjectNotFound: (.Arduino. IDE:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.0.1
Starting backend process. PID: 6608
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/HuhDO/.theia'
root INFO Backend Object.initialize: 3.5 ms [Finished 4.057 s after backend start]
root INFO Backend Object.configure: 2.7 ms [Finished 4.057 s after backend start]
root INFO Backend MessagingContribution.onStart: 1.2 ms [Finished 4.057 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 4.166 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 4.166 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.1 ms [Finished 4.166 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 109.3 ms [Finished 4.167 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 4.167 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 1.6 ms [Finished 4.168 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 4.168 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 0.7 ms [Finished 4.169 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 4.170 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 0.9 ms [Finished 4.171 s after backend start]
root INFO Backend NodeFileUploadService.configure: 1.7 ms [Finished 4.171 s after backend start]
daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 0.7 ms [Finished 4.172 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 0.5 ms [Finished 4.172 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 4.173 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 4.173 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 4.174 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.0 ms [Finished 4.175 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 3.3 ms [Finished 4.178 s after backend start]
root INFO Theia app listening on http://localhost:65098.
root INFO Finished starting backend application: 8.1 ms [Finished 4.182 s after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/HuhDO/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/HuhDO/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\HuhDO\.arduinoProIDE\plugins does not exist.
Restoring workspace roots: c:\Users\HuhDO\Documents\Arduino\!Heat_Exchanger\Temp_Controller_v009_TEST_RIG
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
root INFO Resolve plugins list: 134.4 ms [Finished 4.307 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 8.4 ms [Finished 4.315 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 8.6 ms [Finished 4.324 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 27.1 ms [Finished 4.351 s after backend start]
daemon INFO INFO[0000] Using config file: c:\Users\HuhDO\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.28.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"65099"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 31.1 ms [Finished 4.382 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 4.3 ms [Finished 4.386 s after backend start]
daemon INFO INFO[0000] Loading hardware from: C:\Users\HuhDO\AppData\Local\Arduino15\packages
daemon INFO INFO[0000] Loading package arduino from: C:\Users\HuhDO\AppData\Local\Arduino15\packages\arduino\hardware
root INFO Deployed backend plugin "vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 390.7 ms [Finished 4.777 s after backend start]
daemon INFO INFO[0000] Checking signature error="opening signature file: open C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="arduino:avr@1.8.6"
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\3.4.1\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\3.4.1\\installed.json" signatureFile="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\3.4.1\\installed.json.sig"
INFO[0000] Loaded platform platform="arduino:mbed_rp2040@3.4.1"
INFO[0000] Loaded platform platform="arduino:samd@1.8.13"
INFO[0000] Checking existence of 'tools' path: C:\Users\HuhDO\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\HuhDO\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool tool="arduino:CMSIS@4.5.0"
INFO[0000] Loaded tool tool="arduino:CMSIS-Atmel@1.2.0"
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.2.1"
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loaded tool tool="arduino:bossac@1.7.0-arduino3"
INFO[0000] Loaded tool tool="arduino:bossac@1.9.1-arduino2"
INFO[0000] Loaded tool tool="arduino:dfu-util@0.10.0-arduino1"
INFO[0000] Loaded tool tool="arduino:openocd@0.10.0-arduino7"
INFO[0000] Loaded tool tool="arduino:openocd@0.11.0-arduino2"
INFO[0000] Loaded tool tool="arduino:rp2040tools@1.0.6"
INFO[0000] Loading package builtin from: C:\Users\HuhDO\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\HuhDO\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\HuhDO\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@0.9.2"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.2"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.5"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.0.0"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.1.0"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.2.1"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.0-rc1"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.1"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.9.1"
INFO[0000] Loading hardware from: C:\Users\HuhDO\Documents\Arduino\hardware
INFO[0000] Loading package espressif from: C:\Users\HuhDO\Documents\Arduino\hardware\espressif
INFO[0000] Loaded platform platform="espressif:esp32@2.0.0"
INFO[0000] Checking signature index="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir dir="C:\\Users\\HuhDO\\Documents\\Arduino\\hardware\\espressif\\esp32\\libraries" location=platform
INFO[0000] Adding libraries dir dir="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\3.4.1\\libraries" location=platform
INFO[0000] Adding libraries dir dir="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Adding libraries dir dir="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
INFO[0000] Loading libraries index file index="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\library_index.json"
INFO[0000] Adding libraries dir dir="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir dir="C:\\Users\\HuhDO\\Documents\\Arduino\\libraries" location=user
root INFO Deployed backend plugin "vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 314.8 ms [Finished 5.092 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 327.2 ms [Finished 5.419 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 308.2 ms [Finished 5.727 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 300.3 ms [Finished 6.028 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 249.7 ms [Finished 6.277 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 324.0 ms [Finished 6.602 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 291.5 ms [Finished 6.893 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 353.9 ms [Finished 7.247 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 178.1 ms [Finished 7.425 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 407.7 ms [Finished 7.833 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 289.6 ms [Finished 8.122 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 299.0 ms [Finished 8.421 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 297.5 ms [Finished 8.719 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 231.8 ms [Finished 8.951 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 282.9 ms [Finished 9.234 s after backend start]
root INFO Waiting for the deploy of the language plugins took: 4142.419400000945 ms.
root INFO Deploy plugins list: 134.4 ms [Finished 9.241 s after backend start]
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO INFO[0004] starting discovery builtin:serial-discovery process
INFO[0004] starting discovery builtin:mdns-discovery process
daemon INFO INFO[0005] started discovery builtin:serial-discovery process
INFO[0005] sending command HELLO 1 "arduino-cli 0.28.0" to discovery builtin:serial-discovery
daemon INFO INFO[0005] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0005] sending command START_SYNC to discovery builtin:serial-discovery
daemon INFO INFO[0005] from discovery builtin:serial-discovery received message type: start_sync, message: OK
daemon INFO INFO[0005] from discovery builtin:serial-discovery received message type: add, port: COM1
daemon INFO INFO[0005] started discovery builtin:mdns-discovery process
INFO[0005] sending command HELLO 1 "arduino-cli 0.28.0" to discovery builtin:mdns-discovery
daemon INFO INFO[0005] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0005] sending command START_SYNC to discovery builtin:mdns-discovery
discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[]}},"error":""}
daemon INFO INFO[0005] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 108.7 ms [Finished 5.691 s after frontend start]
root INFO Start frontend contributions: 382.0 ms [Finished 5.920 s after frontend start]
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO ------- SERIALIZED LAYOUT DATA -------
root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///c%3A/Users/HuhDO/Documents/Arduino/%21Heat_Exchanger/Temp_Controller_v009_TEST_RIG/Temp_Controller_v009_TEST_RIG.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":114,\"column\":9},\"position\":{\"lineNumber\":114,\"column\":9}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":96,\"column\":1},\"firstPositionDeltaTop\":-18},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":723,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///c%3A/Users/HuhDO/Documents/Arduino/%21Heat_Exchanger/Temp_Controller_v009_TEST_RIG/EEPROM_DATA.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":50,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///c%3A/Users/HuhDO/Documents/Arduino/%21Heat_Exchanger/Temp_Controller_v009_TEST_RIG/Graph.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":451,\"column\":5},\"position\":{\"lineNumber\":451,\"column\":5}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":337,\"column\":1},\"firstPositionDeltaTop\":-25},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":471,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///c%3A/Users/HuhDO/Documents/Arduino/%21Heat_Exchanger/Temp_Controller_v009_TEST_RIG/TempCntrlConstants.h","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":147,\"column\":30},\"position\":{\"lineNumber\":147,\"column\":30}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":133,\"column\":1},\"firstPositionDeltaTop\":-11},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":196,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///c%3A/Users/HuhDO/Documents/Arduino/%21Heat_Exchanger/Temp_Controller_v009_TEST_RIG/pump.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":31,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":2}},"mainPanelPinned":[false,false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"problems"},"innerWidgetState":"{}"}],"currentIndex":0}},"pinned":[false,false],"size":74,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":266},"rightPanel":{"type":"sidepanel","items":[]}}
root INFO ------- END SERIALIZED LAYOUT DATA -------
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c] Waiting for backend deployment: 66.2 ms [Finished 5.984 s after frontend start]
sketches-service WARN Mismatching sketch file <i2lcd.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <GetESR.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <get_log.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <ReadADC.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <RvalOut.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <CheckUJT.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <GetVloss.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <lcd_draw.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <ShowData.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <CheckPins.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <PinLayout.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <sleep_5ms.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <UfAusgabe.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <ReadBigCap.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <RefVoltage.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <wait1000ms.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <EntladePins.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <GetRLmultip.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <sampling_lc.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <samplingADC.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <Calibrate_UR.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <DisplayValue.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <GetFrequency.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <lcd_hw_4_bit.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <lcd_routines.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <ReadCapacity.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <Sampling_cap.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <Battery_check.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <ChargePin10ms.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <EE_check_init.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <function_menu.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <GetResistance.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <sampling_xtal.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <Eeprom_Functions.ino> and sketch folder name <WireBot_V2_7>. Skipping
sketches-service WARN Mismatching sketch file <Eeprom_Functions.ino> and sketch folder name <WireBot_V2_9>. Skipping
sketches-service WARN Mismatching sketch file <CalibrationCap.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <ReadInductance.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <show_Resis_Cap.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <Eeprom_Functions.ino> and sketch folder name <WireBot_V2_10>. Skipping
sketches-service WARN Mismatching sketch file <E_Print_Functions.ino> and sketch folder name <WireBot_V2_7>. Skipping
sketches-service WARN Mismatching sketch file <E_Print_Functions.ino> and sketch folder name <WireBot_V2_9>. Skipping
sketches-service WARN Mismatching sketch file <wait_for_key_ms.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <E_Print_Functions.ino> and sketch folder name <WireBot_V2_10>. Skipping
sketches-service WARN Mismatching sketch file <A_Primary_Functions.ino> and sketch folder name <WireBot_V2_7>. Skipping
sketches-service WARN Mismatching sketch file <F_Utility_Functions.ino> and sketch folder name <WireBot_V2_7>. Skipping
sketches-service WARN Mismatching sketch file <A_Primary_Functions.ino> and sketch folder name <WireBot_V2_9>. Skipping
sketches-service WARN Mismatching sketch file <F_Utility_Functions.ino> and sketch folder name <WireBot_V2_9>. Skipping
sketches-service WARN Mismatching sketch file <A_Primary_Functions.ino> and sketch folder name <WireBot_V2_10>. Skipping
sketches-service WARN Mismatching sketch file <F_Utility_Functions.ino> and sketch folder name <WireBot_V2_10>. Skipping
sketches-service WARN Mismatching sketch file <CheckRotaryEncoder.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <lcd_routines_serial.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <message_key_released.ino> and sketch folder name <ArduTester_1_13>. Skipping
sketches-service WARN Mismatching sketch file <UI_Functions.ino> and sketch folder name <WireBot_basic05>. Skipping
sketches-service WARN Mismatching sketch file <UI_Functions.ino> and sketch folder name <WireBot_basic06>. Skipping
sketches-service WARN Mismatching sketch file <UI_Functions.ino> and sketch folder name <WireBot_basic07>. Skipping
sketches-service WARN Mismatching sketch file <UI_Functions.ino> and sketch folder name <WireBot_basic08>. Skipping
sketches-service WARN Mismatching sketch file <UI_Functions.ino> and sketch folder name <WireBot_basic09>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_V2_1>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_V2_2>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_V2_3>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_7>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_9>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <CRUNCH_TIME_5>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <CRUNCH_TIME_6>. Skipping
sketches-service WARN Mismatching sketch file <C_New_Roll_Brach.ino> and sketch folder name <WireBot_V2_5>. Skipping
sketches-service WARN Mismatching sketch file <C_New_Roll_Brach.ino> and sketch folder name <WireBot_V2_6>. Skipping
sketches-service WARN Mismatching sketch file <Eeprom_Functions.ino> and sketch folder name <WireBot_V2_6>. Skipping
sketches-service WARN Mismatching sketch file <Eeprom_Functions.ino> and sketch folder name <WireBot_V2_8>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_10>. Skipping
sketches-service WARN Mismatching sketch file <PrintFunctions.ino> and sketch folder name <WireBot_basic02>. Skipping
sketches-service WARN Mismatching sketch file <B_UI_Functions.ino> and sketch folder name <WireBot_basic04>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_V2_1>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_V2_2>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_V2_3>. Skipping
sketches-service WARN Mismatching sketch file <D_Print_Functions.ino> and sketch folder name <WireBot_V2_4>. Skipping
sketches-service WARN Mismatching sketch file <E_Print_Functions.ino> and sketch folder name <WireBot_V2_5>. Skipping
sketches-service WARN Mismatching sketch file <E_Print_Functions.ino> and sketch folder name <WireBot_V2_6>. Skipping
sketches-service WARN Mismatching sketch file <E_Print_Functions.ino> and sketch folder name <WireBot_V2_8>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM Manager_v001.ino> and sketch folder name <EEPROM Manager v001>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <CRUNCH_TIME_5>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <CRUNCH_TIME_6>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic05>. Skipping
sketches-service WARN Mismatching sketch file <State_Functions.ino> and sketch folder name <WireBot_basic05>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic06>. Skipping
sketches-service WARN Mismatching sketch file <State_Functions.ino> and sketch folder name <WireBot_basic06>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic07>. Skipping
sketches-service WARN Mismatching sketch file <State_Functions.ino> and sketch folder name <WireBot_basic07>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic08>. Skipping
sketches-service WARN Mismatching sketch file <State_Functions.ino> and sketch folder name <WireBot_basic08>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic09>. Skipping
sketches-service WARN Mismatching sketch file <State_Functions.ino> and sketch folder name <WireBot_basic09>. Skipping
sketches-service WARN Mismatching sketch file <C_Eeprom_Functions.ino> and sketch folder name <WireBot_V2_4>. Skipping
sketches-service WARN Mismatching sketch file <D_Eeprom_Functions.ino> and sketch folder name <WireBot_V2_5>. Skipping
sketches-service WARN Mismatching sketch file <C_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_7>. Skipping
sketches-service WARN Mismatching sketch file <C_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_9>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic010>. Skipping
sketches-service WARN Mismatching sketch file <State_Functions.ino> and sketch folder name <WireBot_basic010>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic011>. Skipping
sketches-service WARN Mismatching sketch file <State_Functions.ino> and sketch folder name <WireBot_basic011>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic012>. Skipping
sketches-service WARN Mismatching sketch file <State_Functions.ino> and sketch folder name <WireBot_basic012>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic013>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic014>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic015>. Skipping
sketches-service WARN Mismatching sketch file <A_StateFunctions.ino> and sketch folder name <WireBot_basic03>. Skipping
sketches-service WARN Mismatching sketch file <B_PrintFunctions.ino> and sketch folder name <WireBot_basic03>. Skipping
sketches-service WARN Mismatching sketch file <E_Utility_Functions.ino> and sketch folder name <WireBot_V2_4>. Skipping
sketches-service WARN Mismatching sketch file <A_Primary_Functions.ino> and sketch folder name <WireBot_V2_5>. Skipping
sketches-service WARN Mismatching sketch file <F_Utility_Functions.ino> and sketch folder name <WireBot_V2_5>. Skipping
sketches-service WARN Mismatching sketch file <A_Primary_Functions.ino> and sketch folder name <WireBot_V2_6>. Skipping
sketches-service WARN Mismatching sketch file <F_Utility_Functions.ino> and sketch folder name <WireBot_V2_6>. Skipping
sketches-service WARN Mismatching sketch file <A_Primary_Functions.ino> and sketch folder name <WireBot_V2_8>. Skipping
sketches-service WARN Mismatching sketch file <F_Utility_Functions.ino> and sketch folder name <WireBot_V2_8>. Skipping
sketches-service WARN Mismatching sketch file <E_Print_Functions.ino> and sketch folder name <WireBot_V2_9v2>. Skipping
sketches-service WARN Mismatching sketch file <C_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_10>. Skipping
sketches-service WARN Mismatching sketch file <A_State_Functions.ino> and sketch folder name <WireBot_basic04>. Skipping
sketches-service WARN Mismatching sketch file <C_Print_Functions.ino> and sketch folder name <WireBot_basic04>. Skipping
sketches-service WARN Mismatching sketch file <U_Utility_Functions.ino> and sketch folder name <WireBot_V2_11>. Skipping
sketches-service WARN Mismatching sketch file <U_Utility_Functions.ino> and sketch folder name <WireBot_V2_12>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <CRUNCH_TIME_6_Plus>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <CRUNCH_TIME_7_Plus>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_basic011>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_basic012>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_basic013>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_basic014>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_basic015>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <WireBot_V2_1>. Skipping
sketches-service WARN Mismatching sketch file <A1_Primary_Functions.ino> and sketch folder name <WireBot_V2_11>. Skipping
sketches-service WARN Mismatching sketch file <A4_Saved_Jobs_Branch.ino> and sketch folder name <WireBot_V2_11>. Skipping
sketches-service WARN Mismatching sketch file <A1_Primary_Functions.ino> and sketch folder name <WireBot_V2_12>. Skipping
sketches-service WARN Mismatching sketch file <A4_Saved_Jobs_Branch.ino> and sketch folder name <WireBot_V2_12>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <WireBot_V2_2>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <WireBot_V2_3>. Skipping
sketches-service WARN Mismatching sketch file <A_Primary_Functions.ino> and sketch folder name <WireBot_V2_9v2>. Skipping
sketches-service WARN Mismatching sketch file <F_Utility_Functions.ino> and sketch folder name <WireBot_V2_9v2>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <CRUNCH_TIME_5>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <CRUNCH_TIME_6>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <CRUNCH_TIME_6_Plus>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <CRUNCH_TIME_7_Plus>. Skipping
sketches-service WARN Mismatching sketch file <A_DeviceState_Functions.ino> and sketch folder name <WireBot_V2_4>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_4>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_5>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_6>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_8>. Skipping
sketches-service WARN Mismatching sketch file <pump.ino> and sketch folder name <Temp_Controller_v008__GRID>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <WireBot_basic013>. Skipping
sketches-service WARN Mismatching sketch file <Print_Functions.ino> and sketch folder name <WireBot_basic014_quick>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <WireBot_basic014>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <WireBot_basic015>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v008__GRID>. Skipping
sketches-service WARN Mismatching sketch file <InvalidInput_Functions.ino> and sketch folder name <WireBot_basic013>. Skipping
sketches-service WARN Mismatching sketch file <InvalidInput_Functions.ino> and sketch folder name <WireBot_basic014>. Skipping
sketches-service WARN Mismatching sketch file <InvalidInput_Functions.ino> and sketch folder name <WireBot_basic015>. Skipping
sketches-service WARN Mismatching sketch file <U_Utility_Functions.ino> and sketch folder name <WireBot_V2_10_print>. Skipping
sketches-service WARN Mismatching sketch file <A2_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_11>. Skipping
sketches-service WARN Mismatching sketch file <A2_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_12>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_9v2>. Skipping
sketches-service WARN Mismatching sketch file <Simple_Button.ino> and sketch folder name <Simple_Button_function>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v003_Graph2>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v003_Graph3>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v007__STATS>. Skipping
sketches-service WARN Mismatching sketch file <pump.ino> and sketch folder name <Temp_Controller_v009_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <CRUNCH_TIME_6_Plus>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <CRUNCH_TIME_7_Plus>. Skipping
sketches-service WARN Mismatching sketch file <Utility_Functions.ino> and sketch folder name <WireBot_basic014_quick>. Skipping
sketches-service WARN Mismatching sketch file <A1_Primary_Functions.ino> and sketch folder name <WireBot_V2_10_print>. Skipping
sketches-service WARN Mismatching sketch file <A4_Saved_Jobs_Branch.ino> and sketch folder name <WireBot_V2_10_print>. Skipping
sketches-service WARN Mismatching sketch file <C_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_8>. Skipping
sketches-service WARN Mismatching sketch file <pump.ino> and sketch folder name <Temp_Controller_v0010_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <pump.ino> and sketch folder name <Temp_Controller_v0011_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v004_2ndTemp>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v006__HX8357>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v009_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <pump.ino> and sketch folder name <Temp_Controller_v009_TEST_RIG>. Skipping
sketches-service WARN Mismatching sketch file <WireBot_V2_6_onefile.ino> and sketch folder name <WireBot_V2_5_onefile>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v0010_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v0011_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v009_TEST_RIG>. Skipping
sketches-service WARN Mismatching sketch file <A3_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_11>. Skipping
sketches-service WARN Mismatching sketch file <A3_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_12>. Skipping
sketches-service WARN Mismatching sketch file <C_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_9v2>. Skipping
sketches-service WARN Mismatching sketch file <Graph.ino> and sketch folder name <Temp_Controller_v005__GraphTime>. Skipping
sketches-service WARN Mismatching sketch file <DeviceState_Functions.ino> and sketch folder name <WireBot_basic014_quick>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v008__GRID>. Skipping
sketches-service WARN Mismatching sketch file <InvalidInput_Functions.ino> and sketch folder name <WireBot_basic014_quick>. Skipping
sketches-service WARN Mismatching sketch file <A2_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_10_print>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v003_Graph2>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v003_Graph3>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v007__STATS>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v004_2ndTemp>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v006__HX8357>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v009_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v0010_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v0011_DS18B20>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v009_TEST_RIG>. Skipping
sketches-service WARN Mismatching sketch file <A3_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_10_print>. Skipping
sketches-service WARN Mismatching sketch file <PowerDoor_Class.ino> and sketch folder name <examples>. Skipping
sketches-service WARN Mismatching sketch file <EEPROM_DATA.ino> and sketch folder name <Temp_Controller_v005__GraphTime>. Skipping
sketches-service WARN Mismatching sketch file <Eeprom_Functions.ino> and sketch folder name <WireBot_V2_7_copy_20210417174059>. Skipping
sketches-service WARN Mismatching sketch file <E_Print_Functions.ino> and sketch folder name <WireBot_V2_7_copy_20210417174059>. Skipping
sketches-service WARN Mismatching sketch file <A_Primary_Functions.ino> and sketch folder name <WireBot_V2_7_copy_20210417174059>. Skipping
sketches-service WARN Mismatching sketch file <F_Utility_Functions.ino> and sketch folder name <WireBot_V2_7_copy_20210417174059>. Skipping
sketches-service WARN Mismatching sketch file <Utilities.ino> and sketch folder name <WiFi_RTC_DISPLAY_TEST9>. Skipping
sketches-service WARN Mismatching sketch file <Utilities.ino> and sketch folder name <WiFi_RTC_DISPLAY_TEST10>. Skipping
sketches-service WARN Mismatching sketch file <B_Admin_Branch_Functions.ino> and sketch folder name <WireBot_V2_7_copy_20210417174059>. Skipping
sketches-service WARN Mismatching sketch file <C_New_Roll_Branch_Functions.ino> and sketch folder name <WireBot_V2_7_copy_20210417174059>. Skipping
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c] Sync of 21 plugins: 632.8 ms [Finished 6.616 s after frontend start]
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812) starting instance
root INFO <<< The layout has been successfully restored.
root INFO Initialize the workbench layout: 1036.1 ms [Finished 6.975 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][marus25.cortex-debug]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][vscode.cpp]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][vscode.json]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][vscode.json-language-features]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c] Load contributions of 21 plugins: 141.3 ms [Finished 7.117 s after frontend start]
root WARN Frontend I.onDidInitializeLayout took longer than the expected maximum 100 milliseconds: 144.1 ms [Finished 7.120 s after frontend start]
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(cortex-debug@0.3.10 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5812): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 5812] PLUGIN_HOST(5812): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][marus25.cortex-debug]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][arduino.vscode-arduino-tools]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][vscode.cpp]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][vscode.json]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][vscode.json-language-features]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-bg]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-hu]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-ko]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-pl]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-uk]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [2027e58c-1e13-449f-849c-a926b3b96c7c] Start of 21 plugins: 665.2 ms [Finished 7.789 s after frontend start]
root INFO Frontend application start: 2597.6 ms [Finished 12.544 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 938.8 ms [Finished 8.060 s after frontend start]
root INFO Changed application state from 'initialized_layout' to 'ready'.
Checking for update
Update for version 2.0.1 is not available (latest version: 2.0.1, downgrade is allowed).
root ERROR ---- !!!SLOW!!! DURATION: search took 625.320 ms. Args: [{"type":"Updatable"}] ----
root INFO Starting language server: arduino:samd:mkrwifi1010
daemon INFO INFO[0009] Searching tools required for board arduino:samd:mkrwifi1010
daemon INFO INFO[0009] Required tool tool="arduino:CMSIS@4.5.0"
INFO[0009] Required tool tool="arduino:CMSIS-Atmel@1.2.0"
INFO[0009] Required tool tool="arduino:arduinoOTA@1.2.1"
INFO[0009] Required tool tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0009] Required tool tool="arduino:bossac@1.7.0-arduino3"
INFO[0009] Required tool tool="arduino:openocd@0.10.0-arduino7"
INFO[0009] Adding libraries dir dir="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0009] Adding libraries dir dir="C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
INFO[0009] Adding libraries dir dir="C:\\Users\\HuhDO\\Documents\\Arduino\\libraries" location=user
daemon INFO INFO[0011] Resolving include FlashStorage_SAMD.h for arch samd
INFO[0011] found better lib lib=FlashStorage_SAMD prio=64D
daemon INFO INFO[0011] Resolving include SPI.h for arch samd
INFO[0011] found better lib lib=SPI prio=64C
daemon INFO INFO[0011] Resolving include WiFiNINA.h for arch samd
INFO[0011] found better lib lib=WiFiNINA prio=643
daemon INFO INFO[0011] Resolving include RTCZero.h for arch samd
INFO[0011] found better lib lib=RTCZero prio=64D
daemon INFO INFO[0011] Resolving include Adafruit_GFX.h for arch samd
INFO[0011] found better lib lib="Adafruit GFX Library" prio=517
daemon INFO INFO[0012] Resolving include Adafruit_I2CDevice.h for arch samd
INFO[0012] found better lib lib="Adafruit BusIO" prio=3EB
daemon INFO INFO[0012] Resolving include Wire.h for arch samd
INFO[0012] found better lib lib=Wire prio=64C
daemon INFO INFO[0012] Resolving include Adafruit_HX8357.h for arch samd
INFO[0012] found better lib lib="Adafruit HX8357 Library" prio=517
daemon INFO INFO[0012] Resolving include OneWire.h for arch samd
INFO[0012] found better lib lib=OneWire prio=643
daemon INFO INFO[0012] Resolving include DallasTemperature.h for arch samd
INFO[0012] found better lib lib=DallasTemperature prio=643
daemon INFO INFO[0016] Searching tools required for board arduino:samd:mkrwifi1010
INFO[0016] Required tool tool="arduino:CMSIS@4.5.0"
INFO[0016] Required tool tool="arduino:CMSIS-Atmel@1.2.0"
INFO[0016] Required tool tool="arduino:arduinoOTA@1.2.1"
INFO[0016] Required tool tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0016] Required tool tool="arduino:bossac@1.7.0-arduino3"
INFO[0016] Required tool tool="arduino:openocd@0.10.0-arduino7"
BTW it reverted to default when it started from powershell without restarting my puter.
