Hi, so I am just working on a little project of mine and after many many many hours of problemsolving I've got most everything down on how to use the 2.4" Touchscreen TFThttps://www.amazon.com/HiLetgo-Display-ILI9341-240X320-Arduino/dp/B0722DPHN6/ref=sr_1_2_sspa?keywords=hiletgo+arduino+tft+2.4%22+touchscreen+lcd+shield&qid=1552120341&s=gateway&sr=8-2-spons&psc=1
However, I've been stuck for quite a while now on how to move an onscreen button. I can use it alright, but only in a certain spot. I think the problem may lie in having to create new pixel x and y places but am pretty confused about it. Basically, I am unable to figure out how to move a button on the screen to a new spot, as whenever i move it, it shows up, but nothing happens when I touch it.
Here's my code (to simplify matters I have been trying to figure it out on a button example code and then carry over whatever I figure out to my actual project:)
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
#define MINPRESSURE 200
#define MAXPRESSURE 1000
const int XP = 8, XM = A2, YP = A3, YM = 9; //320x240 ID=0x9341
const int TS_LEFT = 70, TS_RT = 885, TS_TOP = 899, TS_BOT = 117;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button on_btn, off_btn;
int pixel_x, pixel_y; //Touch_getXY() updates global vars
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); //because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
return pressed;
#define BLACK 0x0000
#define CYAN 0x07FF
#define WHITE 0xFFFF
#define RED 0xB800
#define GREEN 0x02E1
void setup(void) {
uint16_t ID = tft.readID();
Serial.print("TFT ID = 0x");
Serial.println(ID, HEX);
Serial.println("Calibrate for your Touch Panel");
if (ID == 0xD3D3) ID = 0x9486;
tft.begin(ID);
tft.setRotation(1);
tft.fillScreen(BLACK);
on_btn.initButton(&tft, 60, 200, 100, 40, WHITE, CYAN, BLACK, "ON", 2);
off_btn.initButton(&tft, 180, 200, 100, 40, WHITE, CYAN, BLACK, "OFF", 2);
on_btn.drawButton(false);
off_btn.drawButton(false);
tft.fillRect(40, 80, 160, 80, RED);
void loop(void) {
bool down = Touch_getXY();
on_btn.press(down && on_btn.contains(pixel_x, pixel_y));
off_btn.press(down && off_btn.contains(pixel_x, pixel_y));
if (on_btn.justReleased())
on_btn.drawButton();
if (off_btn.justReleased())
off_btn.drawButton();
if (on_btn.justPressed()) {
on_btn.drawButton(true);
tft.fillRect(40, 80, 160, 80, GREEN);
if (off_btn.justPressed()) {
off_btn.drawButton(true);
I a unsure how to move the btn (button) to a new location. I assume by changing the "60" and "200" valuables as that does indeed move the button to a new location.
However, if I do change it to:
on_btn.initButton(&tft, 50, 50, 100, 40, WHITE, CYAN, BLACK, "ON", 2);
The button moves to the spot desginated (50, 50) like how I want, but when I press it, it no longer recognizes when I press it.
Using an Arduino Mega 2560 and any help would be greatly appreciated!
Thanks!
