Hello everyone I have the Idea of make a RTC with a RTC Module and 7segments 4 digits to display the time, all this with a Leonardo board and only that.
Digital Pins from 6 to 13 are reserved to the 7segments and Digital Pin 14,15,16 and 5 controls the digits in the display; digital pins 2 and 3 are reserved for the I2C RTC module.
the problem is that when I was using my code for the 7 segment display with that setup only works the digit with the pin 5 and the digital pins 14, 15 and 16 didn't work, what i have to do? are something that i have done wrong?
thank you guys for the help and advices.
this is my setup:
and this is my code that only must handle the display:
// display 4 digit 7 segments
int Digit1 = 14;
int Digit2 = 15;
int Digit3 = 16;
int Digit4 = 5;
int SegmentA = 6;
int SegmentB = 7;
int SegmentC = 8;
int SegmentD = 9;
int SegmentE = 10;
int SegmentF = 11;
int SegmentG = 12;
int SegmentDP = 13;
byte H = 0;
byte h = 5;
byte M = 2;
byte m = 2;
int ms = 0;
byte s = 0;
unsigned long mills;
unsigned long old_mills;
byte del = 1;
int calib = 235;
//235 se adelanta unos milisegundos
//236 se atraza unos milisegundos
// cambiar el "del" aumenta o disminuye mucho la velocidad
pinMode(Digit1, OUTPUT);
pinMode(Digit2, OUTPUT);
pinMode(Digit3, OUTPUT);
pinMode(Digit4, OUTPUT);
pinMode(SegmentA, OUTPUT);
pinMode(SegmentB, OUTPUT);
pinMode(SegmentC, OUTPUT);
pinMode(SegmentD, OUTPUT);
pinMode(SegmentE, OUTPUT);
pinMode(SegmentF, OUTPUT);
pinMode(SegmentG, OUTPUT);
pinMode(SegmentDP, OUTPUT);
ms = ms + 1;
if (ms >= calib){
ms = 0;
s= s + 1;
if (s >= 60){
s = 0;
m = m + 1;
if (s%2){
digitalWrite(SegmentDP,LOW);
else{
digitalWrite(SegmentDP,HIGH);
if (m >= 10){
m = 0;
M = M + 1;
if (M >=6){
M = 0;
h++;
if ( h >= 10){
h = 0;
H = H + 1;
if (H >= 10){
H = 0;
if ((H==1) && (h==3)){
H=0;
h=1;
numero(m);
digitalWrite(Digit1,HIGH);
delay(del);
digitalWrite(Digit1,LOW);
numero(M);
digitalWrite(Digit2,HIGH);
delay(del);
digitalWrite(Digit2,LOW);
numero(h);
digitalWrite(Digit3,HIGH);
delay(del);
digitalWrite(Digit3,LOW);
numero(H);
digitalWrite(Digit4,HIGH);
delay(del);
digitalWrite(Digit4,LOW);
//ultimo ajuste
delayMicroseconds(10);
// numeros
void numero(int i) //dibuja el numero especificado antes se debe encender el digito
switch (i){
case 1:
digitalWrite(SegmentA, HIGH);
digitalWrite(SegmentB, LOW);
digitalWrite(SegmentC, LOW);
digitalWrite(SegmentD, HIGH);
digitalWrite(SegmentE, HIGH);
digitalWrite(SegmentF, HIGH);
digitalWrite(SegmentG, HIGH);
case 2:
digitalWrite(SegmentA, LOW);
digitalWrite(SegmentC, HIGH);
digitalWrite(SegmentD, LOW);
digitalWrite(SegmentE, LOW);
digitalWrite(SegmentG, LOW);
case 3:
case 4:
digitalWrite(SegmentF, LOW);
case 5:
digitalWrite(SegmentB, HIGH);
case 6:
case 7:
case 8:
case 9:
case 0:
sorry for my poor English
