Problem was solved by an example I found from some ebay site. I changed connection for some other reasons to SPI.
The code I used:
A really simple analog clock
Tested and worked with:
Teensy3,Teensy3.1,Arduino UNO,Arduino YUN,Arduino Leonardo,Stellaris
Works with Arduino 1.0.6 IDE, Arduino 1.5.8 IDE, Energia 0013 IDE
---------------> http://www.buydisplay.com
#include <SPI.h>
#include <RA8875.h>
//Arduino DUE,Arduino mega2560
#define RA8875_RESET 24
#define RA8875_INT 23
#define RA8875_CS 22
//#if defined(NEEDS_SET_MODULE)//Energia, this case is for stellaris/tiva
//RA8875 tft = RA8875(3);//select SPI module 3
for module 3 (stellaris)
SCLK: PD_0
MOSI: PD_3
MISO: PD_2
SS: PD_1
//#else
RA8875 tft = RA8875(RA8875_CS,RA8875_RESET);
//#endif
uint16_t ccenterx,ccentery;//center x,y of the clock
const uint16_t cradius = 110;//radius of the clock
const float scosConst = 0.0174532925;
float sx = 0, sy = 1, mx = 1, my = 0, hx = -1, hy = 0;
float sdeg=0, mdeg=0, hdeg=0;
uint16_t osx,osy,omx,omy,ohx,ohy;
uint16_t x0 = 0, x1 = 0, yy0 = 0, yy1 = 0;
uint32_t targetTime = 0;// for next 1 second timeout
uint8_t hh,mm,ss; //containers for current time
void drawClockFace(){
tft.fillCircle(ccenterx, ccentery, cradius, RA8875_BLUE);
tft.fillCircle(ccenterx, ccentery, cradius-4, RA8875_BLACK);
// Draw 12 lines
for(int i = 0; i<360; i+= 30) {
sx = cos((i-90)*scosConst);
sy = sin((i-90)*scosConst);
x0 = sx*(cradius-4)+ccenterx;
yy0 = sy*(cradius-4)+ccentery;
x1 = sx*(cradius-11)+ccenterx;
yy1 = sy*(cradius-11)+ccentery;
tft.drawLine(x0, yy0, x1, yy1, RA8875_BLUE);
static uint8_t conv2d(const char* p) {
uint8_t v = 0;
if ('0' <= *p && *p <= '9') v = *p - '0';
return 10 * v + *++p - '0';
void setup(void) {
tft.begin(RA8875_480x272);
tft.setTextColor(RA8875_WHITE, RA8875_BLACK);
ccenterx = tft.width()/2;
ccentery = tft.height()/2;
osx = ccenterx;
osy = ccentery;
omx = ccenterx;
omy = ccentery;
ohx = ccenterx;
ohy = ccentery;
drawClockFace();// Draw clock face
//get current time from compiler
hh = conv2d(__TIME__);
mm = conv2d(__TIME__+3);
ss = conv2d(__TIME__+6);
targetTime = millis() + 1000;
void drawClockHands(uint8_t h,uint8_t m,uint8_t s){
// Pre-compute hand degrees, x & y coords for a fast screen update
sdeg = s * 6; // 0-59 -> 0-354
mdeg = m * 6 + sdeg * 0.01666667; // 0-59 -> 0-360 - includes seconds
hdeg = h * 30 + mdeg * 0.0833333; // 0-11 -> 0-360 - includes minutes and seconds
hx = cos((hdeg-90)*scosConst);
hy = sin((hdeg-90)*scosConst);
mx = cos((mdeg-90)*scosConst);
my = sin((mdeg-90)*scosConst);
sx = cos((sdeg-90)*scosConst);
sy = sin((sdeg-90)*scosConst);
// Erase just old hand positions
tft.drawLine(ohx, ohy, ccenterx+1, ccentery+1, RA8875_BLACK);
tft.drawLine(omx, omy, ccenterx+1, ccentery+1, RA8875_BLACK);
tft.drawLine(osx, osy, ccenterx+1, ccentery+1, RA8875_BLACK);
// Draw new hand positions
tft.drawLine(hx*(cradius-28)+ccenterx+1, hy*(cradius-28)+ccentery+1, ccenterx+1, ccentery+1, RA8875_WHITE);
tft.drawLine(mx*(cradius-17)+ccenterx+1, my*(cradius-17)+ccentery+1, ccenterx+1, ccentery+1, RA8875_WHITE);
tft.drawLine(sx*(cradius-14)+ccenterx+1, sy*(cradius-14)+ccentery+1, ccenterx+1, ccentery+1, RA8875_RED);
tft.fillCircle(ccenterx+1, ccentery+1, 3, RA8875_RED);
// Update old x&y coords
osx = sx*(cradius-14)+ccenterx+1;
osy = sy*(cradius-14)+ccentery+1;
omx = mx*(cradius-17)+ccenterx+1;
omy = my*(cradius-17)+ccentery+1;
ohx = hx*(cradius-28)+ccenterx+1;
ohy = hy*(cradius-28)+ccentery+1;
void drawPrintTime(uint16_t x,uint16_t y, uint8_t h,uint8_t m,uint8_t s){
tft.changeMode(TEXT);
tft.setCursor (0, 0);
tft.print ("www.buydisplay.com");
tft.setCursor (x, y);
tft.print(__DATE__);
tft.setCursor (x, y-13);
if (hh > 12) {
if (hh < 22) tft.print('0');
tft.print (hh-12);
else {
if (hh < 10) tft.print('0');
tft.print (hh);
tft.print (':');
if (mm < 10) tft.print('0');
tft.print (mm);
tft.print (':');
if (ss < 10) tft.print('0');
tft.print (ss);
if (hh > 12) {
tft.print(" pm");
else {
tft.print (" am");
tft.changeMode(GRAPHIC);
if (targetTime < millis()) {
targetTime = millis()+1000;
ss++;
if (ss == 60) {
ss = 0;
mm++;
if(mm > 59) {
mm = 0;
hh++;
if (hh > 23) hh = 0;
drawClockHands(hh,mm,ss);
drawPrintTime(34,151,hh,mm,ss);
Desided to share information 'cos someone else might have a same problem…
-TommiP
