That's great. Mind sharing the solution so others with the same issue can learn from it?
sterretje:
yes i have update the code in the first page to be used
Generally, changing a post is considered discourteous if it wrecks the following thread.
vaj4088:
so what do u suggest?
Before, you should have left the post alone. Now, you should put the post back the way that it was.
Then, you should post a reply with the updated code that solved your problem.
vaj4088:
Before, you should have left the post alone. Now, you should put the post back the way that it was.Then, you should post a reply with the updated code that solved your problem.
done
updated code
transmitter code
#include <AESLib.h>
#include <SPI.h>
#include <printf.h>
#include <nRF24L01.h>
#include <RF24_config.h>
#include <RF24.h>
// Funk defines
#define CE_PIN 9
#define CSN_PIN 10
// Funk
// create RF24 radio object using selected CE and CSN pins
RF24 radio(CE_PIN,CSN_PIN);
// Funk
// Pipe Adresse
const uint64_t address = 0xE7E7E7E7E7;
byte key[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
char data3[] = "0123456789012345"; //16 chars == 16 bytes
aes128_enc_single(key, data3);
//Serial.println(sizeof(myData));
printf_begin();
// Funkverbindung
radio.begin();
radio.setPALevel(RF24_PA_MIN);
radio.setChannel(100); // geht bis 125
radio.setDataRate(RF24_1MBPS); // geht bis max. 2MBPS
//radio.setPayloadSize(32);
radio.setAutoAck(0);
radio.enableDynamicPayloads();
radio.setRetries(15,15);
radio.openWritingPipe(address);
radio.printDetails();
Serial.println("encrypted:");
for(int i=0; i<16; i++) {
Serial.print(data3[i]);
radio.write(data3, sizeof(data3));
receiver code
#include <SPI.h>
#include <printf.h>
#include <RF24.h>
#include <AESLib.h>
// Funk defines
#define CE_PIN 9
#define CSN_PIN 10
char data3[16];
// Funk
// Funk
// Pipe Adresse
Serial.begin(115200); //Starten der seriellen Kommunikation mit 9600 baud
// Wird benötigt für die printDetails Funktion
printf_begin();
// Funkverbindung
radio.begin();
radio.openReadingPipe(1,address);
radio.startListening();
if (radio.available()) {
radio.read(data3, sizeof(data3));
aes128_dec_single(key, data3);
Serial.println("Decrypted");
