So I've always built my own Arduinos, but for this new project I decided to buy a Gravitech Arduino Nano 3.0. I also bought an official UNO R3 just to have. I am having problems uploading sketches via USB. I get the following error on both the nano and the uno.
Arduino: 1.6.5 (Windows 7), Board: "Arduino Nano, ATmega328"
Build options changed, rebuilding all
Sketch uses 6,664 bytes (21%) of program storage space. Maximum is 30,720 bytes.
Global variables use 329 bytes (16%) of dynamic memory, leaving 1,719 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b57600 -D -Uflash:w:C:\Users\Dustin\AppData\Local\Temp\build3883939482945049544.tmp/ChickenCoopDoor.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
I am able to upload to both boards via an ArduinoISP board. I can also open the serial monitor and see Serial.print output via the usb, just can't upload sketches.
I am using the latest Arduino IDE. I have the correct boards selected and the correct COM ports. Using a Windows 7 64bit machine, also tried a Windows 8.1 laptop.
Things I have tried:
• Updating and rolling back drivers, from the IDE folder, windows update, and FTDI site.
• Uninstalling and reinstalling everything multiple times, IDE and drivers
• Reloading bootloader via the IDE using my ArduinoISP
• Holding and releasing the reset button many different ways
• 1uF cap soldered across reset and ground(it's removed now)
• Many different USB cables and ports
I've spent most of the day searching every site/thread I could find on the subject and I'm at a loss. Any ideas on what to try would be greatly appreciated. I can load my sketches via the ArduinoISP programmer, but I would rather be able to do it via USB to quickly make changes and read serial output.
Thanks!
