i´m pretty new to electrical engineering and micro controllers. But I want to learn how to get these things running! So I bought a Arduino Due and a 9DOF sensor stick from Sparkfun. I want to read the sensor values and experiment with some filters afterwards. But I have troubles with the reading the most significant 8 bits for each possible axis. The values always jump from about 0-3 to 253-255 with no steps in between.
I wanted to start another topic because I want to know if any Due users have experience with this stick. I am very excited about experimenting with it but this is a bummer right now. I only have this board so I can´t check if this is an issue of the board. Probably the stick is broken, who knows? I hope some one can help me out (:
I have several MCUs but all of them are SPI. Anyway, to determine what is going on with your Due-9DOF Stick, I'd recommend you to start trying to communicate with one of the sensors, let's say the accelerometer, and then with the other two. I assume that you know how accelerometers work. Just in case remember, under steady-state, all the values (x,y,z) should be zero. When the stick is in motion, the values change.
Here a sketch that I have built just for the accelerometer after the chionophilous' tutorial that you have followed. It should work (theoretically). I assume, also, that you have connected 3.3V, GND, SDA and SCL between the stick and due.
It looks like this, even if i don´t move it. Every time the value goes up to 65k the most significant 8 bit part jumps form 0 or 1 to some values around 255.
But I will try to shorten the wires now! I was thinking that 30cm would be ok. But they are probably to long. I will report my results ASAP!
and maybe I soldered it not the right way? This evening I will meet a friend. He has probably some tools to do some troubeshooting. But the soldering points look fine.
Let's put aside for a moment the wiring subject. I want you to try another code (it seems to be the same I gave you). I think we miss nothing if you make a try running it. Here the sketch:
#include <Wire.h>
#define DEVICE (0x53) //ADXL345 device address
#define TO_READ (6) //num of bytes we are going to read each time (two bytes for each axis)
byte buff[TO_READ] ; //6 bytes buffer for saving data read from the device
char str[512]; //string buffer to transform data before sending it to the serial port
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
//Turning on the ADXL345
writeTo(DEVICE, 0x2D, 0);
writeTo(DEVICE, 0x2D, 16);
writeTo(DEVICE, 0x2D, 8);
int regAddress = 0x32; //first axis-acceleration-data register on the ADXL345
int x, y, z;
readFrom(DEVICE, regAddress, TO_READ, buff); //read the acceleration data from the ADXL345
//each axis reading comes in 10 bit resolution, ie 2 bytes. Least Significat Byte first!!
//thus we are converting both bytes in to one int
x = (((int)buff[1]) << 8) | buff[0];
y = (((int)buff[3])<< 8) | buff[2];
z = (((int)buff[5]) << 8) | buff[4];
//we send the x y z values as a string to the serial port
sprintf(str, "%d %d %d", x, y, z);
Serial.print(str);
Serial.write(10);
//It appears that delay is needed in order not to clog the port
delay(15);
void writeTo(int device, byte address, byte val) {
Wire.beginTransmission(device); //start transmission to device
Wire.write(address); // send register address
Wire.write(val); // send value to write
Wire.endTransmission(); //end transmission
void readFrom(int device, byte address, int num, byte buff[]) {
Wire.write(address); //sends address to read from
Wire.beginTransmission(device); //start transmission to device (initiate again)
Wire.requestFrom(device, num); // request 6 bytes from device
int i = 0;
while(Wire.available()) //device may send less than requested (abnormal)
buff[i] = Wire.read(); // receive a byte
i++;
Update: works on an arduino uno without code changes. So the stick is fine. But what could be the problem with the due? The wire library? Can my I2C port be broken? Do I need to clock my cpu down somehow? no idea...
I have read a couple of posts and it looks like given the MCU library was built for AVR 8-bit and that Due is an ARM 32-bit, the difference between architectures could oblige the programmer (us) to consider to implement a solution (changes in the library) to make Due to correctly interpret the MCU data. I mean, a common 16 bit-based system instead of misreadings of standard 32-bit integers that will result in the 16 bit signed data coming out all positive and over 65000 for negatives. Thus, here could be the mystery. Let's grasp a bit about it.
What was the address that ended up working for the ADXL345? I have the DUE and the 10724 sparkfun sensor stick and I can't get any communication up. I just get all 0's. When I print the integer from the Wire.endTransmission I get a 2, which I believe is a NACK from the address transmit (line 200 of Wire.cpp).
I've tried both:
