[SOLVED]Arduino as a SERVER TCP. How to Send packets?
Hello
I have an Arduino DUE+ IoShield A (W5500 from Wiznet). IDE 1.6. Wiznet Ethernet library
I want the Arduino to behave as a TCP Server. This server waits for a client, and sends the client an info packet.
The code is divided in two files, one the server code, and other a .h with the struct of the packet
Server.
#include "packet.h"
#include <Ethernet.h>
 // the media access control (ethernet hardware) address for the shield:
byte mac[] = { 0x00, 0x08, 0xDC, 0x4D, 0xD1, 0x55 };
//the IP address for the shield:
byte ip[] = { 10, 1, 1, 3 };
// the router's gateway address:
byte gateway[] = { 10, 1, 1, 1 };//? Esto no esun gateway, es un nodo.
// the subnet:
byte subnet[] = { 255, 255, 255, 0 };
int Port= 5000;
EthernetServer server = EthernetServer(Port);
  // initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);
  // start listening for clients
  server.begin();
  Info.PacketID= 0x0E;
  Info.ID_track=1;
  Info.Direction=0x00;
  Info.num=10;
  Info.stateA[0]=0x00;
  Info.stateA[1]=0x00;
  Info.stateA[2]=0x00;
  Info.stateA[3]=0x00;
  // if an incoming client connects, there will be bytes available to read:
  if (client) {
    server.write(Info,sizeof(Info));
packet.h
struct Packet{
  byte PacketID;
  byte ID_track;
  byte Direction;
  byte num;
  byte stateA[4];
struct Packet Info;
It gives error in server.write() , no matching function for call... I think that it is beacuse Info is not only an array of bytes but a struct... but I'm not sure
Any help about the server and how to send a data packet structure is welcome.
Thanks
It is client.write(), not server.write(). Something like this:
client.write(Packet, sizeof(Packet));
The Ethernet library included in the IDE is for a WizNet 5100 chip. I'm not sure if the WizNet 5500 is compatible enough to work with the unchanged library. As far as I know there is a Ethernet2 library for that chip.
Thanks for the answers,
I'm using Wiznet Ethernet Library.
Using client.write() returns the same error
Try using a override.
client.write((byte*)info, sizeof(info));
I tried using
The error now changes to: invalid cast from type ...
My bad. Use the "address of info" (ampersand).
client.write((byte*)&info, sizeof(info));
SurferTim:
I hate that error, I have to force myself to actually read my code aloud.
And say, "pointer to address of" or "pointer to value of"
Thank you! It worked!
