[solved] Arduino DUE + 2.8 TFT (ITDB28) + UTFT
Hi!
I’m trying to port a simple program to DUE from MEGA 2560. I’m trying to use the ITDB28 shield from ITEAD studio.
http://www.exp-tech.de/Displays/ITeadstudio-2-8-TFT-Touch-Shield-fuer-Arduino.html
The following code worked on MEGA 2560, but doesn’t work on DUE.
I checked the pins with scope, signals should be fine…I just don’t know what am I doing wrong…
// UTFT_Textrotation_Demo (C)2013 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the textrotation-functions.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
UTFT myGLCD(ITDB28,A5,A4,A3,A2);   // Remember to change the model parameter to suit your display module!
  // Actually not needed
  pinMode(A5, OUTPUT);
  pinMode(A4, OUTPUT);
  pinMode(A3, OUTPUT);
  pinMode(A2, OUTPUT);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(BigFont);
    myGLCD.print("Text rotation", 0, 0);
    myGLCD.setColor(0, 0, 255);
    myGLCD.print("0 degrees", 0, 16, 0);
    myGLCD.print("90 degrees", 319, 0, 90);
    myGLCD.print("180 degrees", 319, 239, 180);
    myGLCD.print("270 degrees", 0, 239, 270);
    myGLCD.setFont(SevenSegNumFont);
    myGLCD.setColor(0, 255, 0);
    myGLCD.print("45", 90, 100, 45);
    myGLCD.print("90", 200, 50, 90);
    myGLCD.print("180", 300, 200, 180);
Problem solved.
The mistake was that MEGA2560 uses the same data lines as Uno and not as MEGA, and that is why it was working on Mega2560 although it was incorrect. Datalines had to be set up as MEGA.
This means using digital pins 22 - 29 for data.
And 38 - 41 for control.
Hi
To which pin you connect the RD,WR,RS,CS and RST pin to in arduino MEGA
How did you initialize the UTFT myGLCD(model,RS,WR,CS,RST)?
Thanks in advance
Cheers
