[solved] Arduino Due: No programmers available for this board.
Somehow I suddenly can't seem to select a programmer to upload code to a Arduino Due.
I'm using Arduino IDE version 1.8.1.3 with Arduino SAM Boards (32-bit ARM Cortex-M3) version 1.6.12. I tried downgrading to 1.6.11. with the hope that would help setting back things straight, but that didn't help. I reinstalled version 1.6.12 and the problem still stands.
The list is not empty when selecting an other Arduino board. When changing the board back to a Due the programmer-list is empty again. Anyone a suggestion I could try?
Edit: This applies both for the Native USB Port as the Programming Port.
Apparently this file was empty:
C:\Users\Me\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\programmers.txt
The problem was solved (as it seams) by adding the contents of of another programmers.txt. I used:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\programmers.txt
