[SOLVED] Arduino Due program does not seem to return from class member
Hello All,
For my new Quadcopter I have been working on some code.
What I am trying to do is declare an object and let the constructor of it do some setup. The problem starts when I call the first member function. The program does not seem to return from that function. It does fully execute the function as I do get the debug message “Ini display:OK” in my OLED display.
After that it seems to hang.
The code of my header file is:
#ifndef QUADCOPTER_H_
#define QUADCOPTER_H_
#include "Telemetry.h"
#include "RCCONTROL.h"
#include "Adafruit_GPS.h"
#include "Adafruit_SSD1306.h"
#define newLine 1
#define sameLine 0
class QuadCopter
public:
	QuadCopter();
	~QuadCopter();
	void secondaryLoop();
	void primaryLoop();
	void initializeTelemetry(USARTClass serialPort);
	void initializeRcInput(HardwareSerial &serialPort);
	void initializeAccelGyro();
	void initializeAltitude();
	void initializeCompass();
	void initializeGps(HardwareSerial &serialPort);
	void initializeDisplay();
	void initializeStorage();
	float rcChannelInput[16];
	void debugMessage(String message, bool nextLine);
private:
	Telemetry *telemetry;
	RCCONTROL *rcControl;
	Adafruit_GPS *GPS;
	Adafruit_SSD1306 *OLEDdisplay;
	uint8_t displayLineCounter;
#endif /* QUADCOPTER_H_*/
The code from my cpp file:
#include "QuadCopter.h"
#include <Wire.h>
QuadCopter::QuadCopter()
	delay(1000);					//Allow power to stabilize
	Wire.begin();
	initializeDisplay();						////@Arduino FORUM Program does not     seem to return from this function
	debugMessage("Quadcopter_V5", newLine);
	debugMessage("By DVDV 2016", newLine);
	initializeRcInput(Serial1);
	initializeTelemetry(Serial2);
	initializeGps(Serial3);
QuadCopter::~QuadCopter()
void QuadCopter::initializeTelemetry(USARTClass serialPort) {
	debugMessage("Ini telemetry:", sameLine);
	Telemetry _telemetry(&serialPort);
	telemetry = &_telemetry;
	debugMessage("OK", newLine);
void QuadCopter::initializeRcInput(HardwareSerial &serialPort) {
	debugMessage("Ini RC:", sameLine);
	RCCONTROL _rcControl(serialPort);
	rcControl = &_rcControl;
	rcControl->setChannelType(1, ANALOG, -50, 50);
	rcControl->setChannelType(2, ANALOG, -50, 50);
	rcControl->setChannelType(3, ANALOG, 0, 100);
	rcControl->setChannelType(4, ANALOG, -50, 50);
	rcControl->setChannelType(5, ANALOG, 0, 5);
	rcControl->setChannelType(6, ANALOG, 0, 5);
	rcControl->setChannelType(7, ANALOG, 0, 5);
	rcControl->setChannelType(8, ANALOG, 0, 5);
	rcControl->setChannelType(9, DIGITAL_2);
	rcControl->setChannelType(10, DIGITAL_3);
	rcControl->setChannelType(11, DIGITAL_3);
	rcControl->setChannelType(12, DIGITAL_3);
	rcControl->setChannelType(13, DIGITAL_3);
	rcControl->setChannelType(14, DIGITAL_3);
	rcControl->setChannelType(15, DIGITAL_3);
	rcControl->setChannelType(16, DIGITAL_2);
void QuadCopter::initializeAccelGyro() {
	debugMessage("Ini AccelGyro:", sameLine);
void QuadCopter::initializeAltitude() {
	debugMessage("Ini Altitude:", sameLine);
void QuadCopter::initializeCompass() {
	debugMessage("Ini Compass:", sameLine);
void QuadCopter::initializeGps(HardwareSerial &serialPort) {
	debugMessage("Ini GPS:", sameLine);
	//Adafruit_GPS _GPS(&serialPort);
	//GPS = &_GPS;
void QuadCopter::initializeDisplay() {
	Adafruit_SSD1306 _OLED(4);
	OLEDdisplay = &_OLED;
	OLEDdisplay->begin(SSD1306_SWITCHCAPVCC, 0x3D);  // initialize with the I2C addr 0x3D or 0x3E(for the 128x64)
	OLEDdisplay->clearDisplay();
	OLEDdisplay->setCursor(0, 0);
	OLEDdisplay->setTextSize(1);
	OLEDdisplay->setTextColor(WHITE);
	OLEDdisplay->display();
	debugMessage("Ini display:", sameLine);
	debugMessage("OK", newLine);				//@Arduino FORUM Program untill here
void QuadCopter::initializeStorage() {
	debugMessage("Ini SD mem:", sameLine);
void QuadCopter::secondaryLoop() {
	//rcControl->process();	//	@DENNIS -> Moet ongeveer 100Hz draaien? Input van receiver is 66Hz, dus nog testen op 50Hz.
	//telemetry->sendData();
void QuadCopter::primaryLoop() {
void QuadCopter::debugMessage(String message, bool nextLine) {
	if (displayLineCounter > 6) {
		displayLineCounter = 0;
	if (nextLine) {
		OLEDdisplay->println(message);
		displayLineCounter++;
	if(!nextLine) {
		OLEDdisplay->print(message);
The code from the ino file:
#include <Wire.h>
#include <spi.h>
	QuadCopter myQuadcopter;
  /* add main program code here */
Can anyone help me in the right direction for this problem? Any other tips & trics for the code I have so far are welcome.
Thanks in advance.
Brand
Found the problem :slight_smile:
It is going wrong with the pointer:
When I change the location of this piece of code:
Anyone who can give me some clarification on this?
It al works fine. However I do not have a clear explaination for it. The updated code can be found here:
#include <Wire.h>
	pinMode(13, OUTPUT);
	digitalWrite(13, LOW);
	delay(500);					//Allow power to stabilize
	Wire.begin();
	Adafruit_SSD1306 _OLED(4);        //@Arduino forum: code has moved to here
	digitalWrite(13, HIGH);
	//GPS = &_GPS;
	if (nextLine) {
	else {
Here:
You create an instance of the Adagruit_SSD1306 object on the stack. You then set OLEDdisplay to point to that object on the stack. When the initializeDisplay function returns, _OLED goes out of scope, and the stack RAM that is used, is released. Sometime later (next time you make a function call, create a local variable, etc.) that area of the stack is over-written with something else.
Read up on variable scope.
Regards, Ray L.
