Hi!
I have Win 7 x86, Arduino IDE 0023 is working great, but the last version has problem to open.
I see this error, and nothing happens. I have java 7 Rountime installed, but I think it doesn' matter because Arduino has his own java in folder.
I have exactly the same problem. I just tried IDE 1.0 and it's working great. When I'm trying to run 1.0.1 after couple of seconds I'm getting this:
Launch4j
An error occurred while starting the application.
I've run "arduino.exe --l4j-debug" command, and the results are (seem to be fine):
I think this is a problem with the Polish translation. It included a translation of an internal string (used as a Date format); the translation makes the string invalid and there's an exception on startup. You could try putting your computer into a language other than Polish or editing the editor.languages.current preference in your preferences.txt file (e.g. setting it to "en").
@mellis big thanks for you and everyone who tried to help, setting
editor.languages.current=en
fixed the problem!
I have English version of Windows, but I use Polish keyboard and regional settings, probably that's why Arduino IDE try to set Polish language.
I added [SOLVED] to the topic name.
there is a problem with java engine initiation with languages/locales other than en/US
Solution is: create a.cmd file with one line:
java\bin\java -Duser.language=en -Duser.country=US -classpath "lib;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
and start Arduino by calling a.cmd - not arduino.exe
It had been starting very slow - after a wait of 1 min or so. Now starts after 5 sec. The only preference I recall changing is “Use external editor”. Running 1.0.3 here under XP. I re selected “use external editor” and it is still OK. Will keep an eye on it.
