[Solved] Arduino Library Ethernet 2.0.0 - Not Work!
Good day.
This library on Arduino Due + Arduino Ethernet R2 does not work for me.
I tried various options for connecting pins and initialization. Compiled a demo project. Nothing helped. Throws an error: Ethernet shield was not found.
With libraries 1.x works without problems.
What to do?
what is what you call "Arduino Ethernet R2"?
Please post a link to your Ethernet 2.0.0 library. In the IDE you only get the Ethernet2 library in version 1.0.4 (currently).
Juraj:
http://shieldlist.org/arduino/ethernet-v5
network shield on WZ 5100
pylon:
I am writing in Visual Studio. But I also tried this library in IDE 1.8.5.
I have access to library 1.1.2 in IDE.
This is not an Ethernet2 library. This is a new version of the Ethernet library. It supports all chips: 5100, 5200 and 5500.
Link to 2.0.0:
Why don't you use version 1.x if that works for you? Are you using the original Arduino Ethernet shield or a clone?
DrAngelOK:
Arduino Shield List: Arduino Ethernet Shield v5.0
I have a clone and it works
pylon:
I am using a Chinese clone.
Library 2.0.0 supports 5100 and 5500.
I have a part of devices with 5100, and a part with 5500.
I wanted to unify the firmware, and not use 2 libraries as before.
Juraj:
Works with library 2.0.0?
There were some features when switching from 1.x
Are the pins the same?
Even the example from the library does not work for me.
DrAngelOK:
yes it works with 2.0.0
what error do you get? how does it not work?
Juraj:
Example: SimpleClient.
Pins connected: SCK,MISO,MOSI - Due 6pin SPI, SS - 10 pin, 3.3v, gnd,reset.
DrAngelOK:
the shield uses 5 V pin. didn't you put it on the Due as a shield?
Shield Arduino not plugged in, and located side by side and connected by wires.
Exactly with the same connection works with the 1.x library
There is a pin 3.3v on the shield
A duplicate of this question was posted on the PJRC forum. Same answer, works fine with the shield plugged into Arduino Due.
Arduino Library Ethernet 2.0.0 - Not Work!!
Version 2.0 uses a faster SPI clock speed. Maybe your wiring is good enough for the slower speed the old version used, but not good enough for the faster clock?
pjrc:
Ok, I will check this option.
pjrc:
Updated IDE - works:
e: \ Soft \ _Run \ Arduino> plink.exe -v -serial COM13
Opening serial device COM13
Configuring baud rate 9600
Configuring 8 data bits
Configuring 1 data bits
Configuring no parity
Configuring XON / XOFF flow control
Initialize Ethernet with DHCP:
DHCP assigned IP 192.168.2.217
connecting to www.google.com ...
connection failed
disconnecting.
Received 0 bytes in 0.0000, rate = 0.00 kbytes / second
Thank you for help.
Solution to the problem:
  1. Update IDE
  2. Deleting:
    if (ETH_MAX_COUNT> 0) {SPI.begin (MY_PIN_ETH);
    Now you do not need to run the SPI library for Ethernet for work.
    For SD only:
    if (SD_MAX_COUNT> 0) {SPI.begin (MY_PIN_SD_0); }
