Hi. I am currently building a fish tank LED light system using an Arduino Mega and Blynk. I have 4 channels of lights (White, Blue, Red and Green for example).
I then have three light modes… lunar, low sun and midsun.
I have separated these light modes using a menu and upon calling each relevant menu, it is SUPPOSED to load each of the channels data to the sliders so that I can adjust if necessary. I then have a save button which will save whatever adjustment I have made.
The problem is, as I move through the different light modes, the previously saved data does not reappear on the slider. For example if I set ch1 on Lunar to 150, if I saved it and then moved to Lowsun menu, and then back to Lunar… I would expect the slider to jump back to 150, but it goes to 0.
Is there a way that I can get it to do this for each of the channels across each of the light modes?
I am very very new to Arduino and Blynk and have limited knowledge of C++ so please be gently.
Here is just a rough copy of code that i have been playing with to learn how to make it work before starting the main sketch.
(Please excuse the messy code, I am just playing about to figure out how to use Blynk)
#define BLYNK_PRINT Serial
#include <BlynkSimpleSerialBLE.h>
#include <SoftwareSerial.h>
char auth[] = "*****HIDDEN*****";
int savechanges; // used to adjust light levels
int lightedit; // as above
SoftwareSerial SerialBLE(10, 11); // RX, TX
struct LEDS // for storing light intensity values
float ch1;
float ch2;
float ch3;
float ch4;
typedef struct LEDS LightColor;
LightColor lunar = { // Lunar colours
0,0,0,0};
LightColor lowsun = { // Lowsun colours
0,0,0,0};
LightColor midsun = { // Midsun colours
0,0,0,0};
LightColor highsun = { // Highsun colours
0,0,0,0};
LightColor edit = { // Used to edit colours
0,0,0,0};
BLYNK_WRITE(V1)
switch (param.asInt())
case 1: // Item 1
lightedit=1; // 0-NOT EDITING 1-EDIT LUNAR 2-EDIT LOWSUN 3-EDIT MIDSUN
Serial.println("Lunar Selected");
Serial.print("lightedit=");
Serial.println(lightedit);
edit.ch1=lunar.ch1;
edit.ch2=lunar.ch2;
edit.ch3=lunar.ch3;
edit.ch4=lunar.ch4;
Blynk.virtualWrite(V2, lunar.ch1);
Blynk.virtualWrite(V3, lunar.ch2);
Blynk.virtualWrite(V4, lunar.ch3);
if (savechanges==1)
Serial.println("SAVED???");
lunar.ch1=edit.ch1;
lunar.ch2=edit.ch2;
lunar.ch3=edit.ch3;
lunar.ch4=edit.ch4;
printall();
case 2: // Item 2
lightedit=2; // 0-NOT EDITING 1-EDIT LUNAR 2-EDIT LOWSUN 3-EDIT MIDSUN
Serial.println("Low Sun selected");
edit.ch1=lowsun.ch1;
edit.ch2=lowsun.ch2;
edit.ch3=lowsun.ch3;
edit.ch4=lowsun.ch4;
Blynk.virtualWrite(V2, lowsun.ch1);
Blynk.virtualWrite(V3, lowsun.ch2);
Blynk.virtualWrite(V4, lowsun.ch3);
if (savechanges==1)
lowsun.ch1=edit.ch1;
lowsun.ch2=edit.ch2;
lowsun.ch3=edit.ch3;
lowsun.ch4=edit.ch4;
printall();
case 3: // Item 3
lightedit=3; // 0-NOT EDITING 1-EDIT LUNAR 2-EDIT LOWSUN 3-EDIT MIDSUN
Serial.println("Mid Sun selected");
edit.ch1=midsun.ch1;
edit.ch2=midsun.ch2;
edit.ch3=midsun.ch3;
edit.ch4=midsun.ch4;
Blynk.virtualWrite(V2, midsun.ch1);
Blynk.virtualWrite(V3, midsun.ch2);
Blynk.virtualWrite(V4, midsun.ch3);
if (savechanges==1)
midsun.ch1=edit.ch1;
midsun.ch2=edit.ch2;
midsun.ch3=edit.ch3;
midsun.ch4=edit.ch4;
printall();
default:
Serial.println("Unknown item selected");
BLYNK_WRITE(V2)
edit.ch1 = param.asInt(); // assigning incoming value from pin V2 to a variable
Serial.print("V2 Slider value is: ");
Serial.println(edit.ch1);
BLYNK_WRITE(V3)
edit.ch2 = param.asInt(); // assigning incoming value from pin V2 to a variable
Serial.print("V3 Slider value is: ");
Serial.println(edit.ch2);
BLYNK_WRITE(V4)
edit.ch3 = param.asInt(); // assigning incoming value from pin V2 to a variable
Serial.print("V4 Slider value is: ");
Serial.println(edit.ch3);
BLYNK_WRITE(V10)
int savechanges = param.asInt(); // assigning incoming value from pin V10 to a variable
savevalues();
BLYNK_WRITE(V11)
int printa = param.asInt();
if (printa==1)
printall();
// Debug console
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
Serial.println("Waiting for connections...");
void savevalues()
if (lightedit==1) // 0-NOT EDITING 1-EDIT LUNAR 2-EDIT LOWSUN 3-EDIT MIDSUN
lunar.ch1=edit.ch1;
lunar.ch2=edit.ch2;
lunar.ch3=edit.ch3;
lunar.ch4=edit.ch4;
Serial.println("SAVE VALUES 1");
printall();
else if (lightedit==2)
Serial.println("SAVE VALUES 2");
printall();
else if (lightedit==3)
Serial.println("SAVE VALUES 3");
printall();
void printall()
Serial.println("=============================================");
Serial.print("LUNAR EDIT: ");Serial.print(edit.ch1);Serial.print(" - ");Serial.print(edit.ch2);Serial.print(" - ");Serial.println(edit.ch3);
Serial.print("LUNAR REAL: ");Serial.print(lunar.ch1);Serial.print(" - ");Serial.print(lunar.ch2);Serial.print(" - ");Serial.println(lunar.ch3);
Serial.print("LOWSUN EDIT: ");Serial.print(edit.ch1);Serial.print(" - ");Serial.print(edit.ch2);Serial.print(" - ");Serial.println(edit.ch3);
Serial.print("LOWSUN REAL: ");Serial.print(lowsun.ch1);Serial.print(" - ");Serial.print(lowsun.ch2);Serial.print(" - ");Serial.println(lowsun.ch3);
Serial.print("MIDSUN EDIT: ");Serial.print(edit.ch1);Serial.print(" - ");Serial.print(edit.ch2);Serial.print(" - ");Serial.println(edit.ch3);
Serial.print("MIDSUN REAL: ");Serial.print(midsun.ch1);Serial.print(" - ");Serial.print(midsun.ch2);Serial.print(" - ");Serial.println(midsun.ch3);
Blynk.run();
