I am replacing an old relay module controlled by Toshiba EX100 PLC with a Arduino Mega controlled system. I was able to easily use a Optocoupler (LTV-8X4) for the inputs to Arduino Mega. My problem is the 24VAC output.
I am using a bridge rectifier (RDBF310-13) as the switch to the motor contactors. The circuit is controlled by a N-Ch Mosfet (MCU80N03A) . The Mosfet gate is controlled by a Optocoupler (LTV-8X7) from a mega pin.
Every time I test the circuit, it either burns the Mosfet or Optocoupler. Can someone tell me what I am missing?
That's clear
A MOSFET deserves some gate voltage for turning on. If it only gets what the motor and rectifier leaves then it has sufficient voltage (5-10V) to kill at least the MOSFET if the current also is high enough.
You better use a relay or SSR or Triac or Thyristor+rectifier to control an AC motor, with an additional voltage to turn the Triac/Thyristor on.
If I remove the optocoupler, it works great. I was trying to buffer the mega with the optocoupler.
Because then the Arduino provides sufficient gate voltage to the MOSFET.
So, this should work without issues?
Yes.
The pulldown resistor (R4?) should be connected to the output pin, not gate, to prevent a voltage divider.
Issues may arise from the lack of insulation between the motor and Arduino.
Use a relay......
Got it working correct after checking my math.
R48 was too high. Change it to 2200 and works fine.
Thanks everyone for the help/options.
