I am trying to upload sketches from my raspberry pi with arch Linux installed to my Arduino Uno.
The same process worked on my laptop but I can't seem to make it work on my PI.
void setup(){
pinMode(13, OUTPUT);
void loop(){
digitalWrite(13, HIGH);
delay(100);
digitalWrite(13, LOW);
delay(100);
Serial.println("Hello world");
[alarm@alarmpi sketchbook]$ cat Makefile
ARDUINO_DIR = /home/alarm/apps/arduino/
ARDUINO_PORT = /dev/ttyACM*
BOARDS_TXT = /home/alarm/apps/arduino/hardware/arduino/avr/boards.txt
USER_LIB_PATH = /home/alarm/sketchbook/libraries
BOARD_TAG = uno
include /home/alarm/Arduino-Makefile/Arduino.mk
[alarm@alarmpi sketchbook]$ make
Arduino.mk Configuration:
- [AUTODETECTED] CURRENT_OS = LINUX
- [USER] ARDUINO_DIR = /home/alarm/apps/arduino/
- [COMPUTED] ARDMK_DIR = /home/alarm/Arduino-Makefile (relative to Common.mk)
- [AUTODETECTED] ARDUINO_VERSION = 185
- [DEFAULT] ARCHITECTURE = avr
- [DEFAULT] ARDMK_VENDOR = archlinux-arduino
- [DEFAULT] ARDUINO_SKETCHBOOK = /home/alarm/sketchbook
- [BUNDLED] AVR_TOOLS_DIR = /home/alarm/apps/arduino//hardware/tools/avr (in Arduino distribution)
- [COMPUTED] ARDUINO_LIB_PATH = /home/alarm/apps/arduino//libraries (from ARDUINO_DIR)
- [COMPUTED] ARDUINO_PLATFORM_LIB_PATH = /home/alarm/apps/arduino//hardware/archlinux-arduino/avr/libraries (from ARDUINO_DIR)
- [COMPUTED] ARDUINO_VAR_PATH = /home/alarm/apps/arduino//hardware/archlinux-arduino/avr/variants (from ARDUINO_DIR)
- [USER] BOARDS_TXT = /home/alarm/apps/arduino/hardware/arduino/avr/boards.txt
- [USER] USER_LIB_PATH = /home/alarm/sketchbook/libraries
- [DEFAULT] PRE_BUILD_HOOK = pre-build-hook.sh
- [USER] BOARD_TAG = uno
- [COMPUTED] CORE = arduino (from build.core)
- [COMPUTED] VARIANT = standard (from build.variant)
- [COMPUTED] OBJDIR = build-uno (from BOARD_TAG)
- [COMPUTED] ARDUINO_CORE_PATH = /home/alarm/apps/arduino//hardware/archlinux-arduino/avr/cores/arduino (from ARDUINO_DIR, BOARD_TAG and boards.txt)
- [DETECTED] MONITOR_BAUDRATE = 9600 (in sketch)
- [DEFAULT] OPTIMIZATION_LEVEL = s
- [DEFAULT] MCU_FLAG_NAME = mmcu
- [DEFAULT] CFLAGS_STD = -std=gnu11
- [DEFAULT] CXXFLAGS_STD = -std=gnu++11
- [COMPUTED] DEVICE_PATH = /dev/ttyACM* (from MONITOR_PORT)
- [DEFAULT] FORCE_MONITOR_PORT =
- [AUTODETECTED] Size utility: AVR-aware for enhanced output
- [COMPUTED] BOOTLOADER_PARENT = /home/alarm/apps/arduino//hardware/archlinux-arduino/avr/bootloaders (from ARDUINO_DIR)
- [COMPUTED] ARDMK_VERSION = 1.6
- [COMPUTED] CC_VERSION = 4.9.2 (avr-gcc)
mkdir -p build-uno
/home/alarm/apps/arduino//hardware/tools/avr/bin/avr-g++ -x c++ -include Arduino.h -MMD -c -D__PROG_TYPES_COMPAT__ -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=185 -DARDUINO_ARCH_AVR -I/home/alarm/apps/arduino//hardware/archlinux-arduino/avr/cores/arduino -I/home/alarm/apps/arduino//hardware/archlinux-arduino/avr/variants/standard -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto -fno-devirtualize -fdiagnostics-color=always blinky.ino -o build-uno/blinky.ino.o
cc1plus: fatal error: Arduino.h: No such file or directory
compilation terminated.
make: *** [/home/alarm/Arduino-Makefile/Arduino.mk:1299: build-uno/blinky.ino.o] Error 1
Is anyone successfully using the Arduino.mk file to compile and upload sketches on there raspberry pi?
Thanks for any help.
