Hey!
I decided to make a simple Arduino reaction game a while ago, and decided to upgrade it. I'm trying to make it so that you can choose the number of games you want to play, and choose a game type; either whoever has the best average over the certain number of games, or whoever has won the most number of games. it works almost perfectly, except for a few major problems;
- In the Overall Time game, the blue players' average jumps randomly, and I have no clue why. I can't figure out what is causing it to do so
- It seems that the blue player is stopped from winning sometime. It is almost always either a tie, and even if I press the blue button, wait, and then press the red one, there is a smaller time difference in favour of blue, then I would've expected. I don't think it is to do with wiring, because I wrote code to test the button and it seemed fine. I'm not 100% sure this is actually a problem
- I tried making unique way to deal with a player just holding the button, or pressing it too early. Basically, in the overall average game, I wanted it to divide your overall time by the number of games you played fairly and add a ten millisecond penalty for every time you forfeit. To do this I added a forfeit counter for each time you forfeited. However this doesn't seem to work. Is my math wrong??? (line 320 and 321)
I know that my code is probably extremely sloppy, and constructive criticism is more than appreciated. My code is pretty long, and I will be very, very grateful for anyone who can help. Thanks in advance!
// include the library code:
#include <LiquidCrystal.h>
//setting button pins
const int rButtonPin = A3;
const int bButtonPin = A2;
const int sButtonPin = A1;
const int LightPin = A0;
//setting button states
int rButtonState = 0;
int bButtonState = 0;
int sButtonState = 0;
//seeing if the player is done or forfeited
int rDone = 0;
int bDone = 0;
int rForfeit = 0;
int bForfeit = 0;
int rForfeitCounter = 0;
int bForfeitCounter = 0;
//counting time
int time = 0;
int timeDone = 0;
int rTime = 0;
int bTime = 0;
int rOvrTime = 0;
int bOvrTime = 0;
int rAvg = 0;
int bAvg = 0;
int rWins = 0;
int bWins = 0;
//command to start the game, and other self explanatory variables
String command;
int game = 0;
int gtype = 0;
int stopPrint = 0;
int numgames = 0;
int Delay = 0;
int gnum = 1;
//setting up the lcd with the pin #'s
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// declaring pins and starting the serial print
pinMode(rButtonPin, INPUT);
pinMode(bButtonPin, INPUT);
pinMode(sButtonPin, INPUT);
pinMode(LightPin, OUTPUT);
//for generating a random number
randomSeed(analogRead(0));
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
//checking the if the button's are on or off
rButtonState = digitalRead(rButtonPin);
bButtonState = digitalRead(bButtonPin);
sButtonState = digitalRead(sButtonPin);
//for the new buttons
digitalWrite(rButtonPin, HIGH);
digitalWrite(bButtonPin, HIGH);
digitalWrite(sButtonPin, HIGH);
switch (game) {
case 0:
GetGame();
case 1:
GetNumGames();
case 2:
PreGame();
case 3:
MainGame();
case 4:
OVRGAME();
case 5:
NUMOFWINSGAME();
case 6:
OVRResults();
case 7:
Restart();
void GetGame () {
if (stopPrint == 0) {
gtype = 0;
lcd.clear();
lcd.print("Choose Game Red");
Serial.print("Press Red Button to change game type\n");
stopPrint = 1;
if (rButtonState == LOW) {
if(gtype == 2) {
gtype = 1;
lcd.clear();
lcd.print("OVR GAME");
delay(300);
gtype = 2;
lcd.clear();
lcd.print("# OF WINS GAME");
delay(300);
if(sButtonState == LOW && gtype > 0) {
game++;
stopPrint = 0;
Serial.print("Game type got: ");
Serial.print(gtype);
void GetNumGames () {
if (stopPrint == 0){
lcd.setCursor(0,1);
lcd.print("Choose Game #: ");
stopPrint = 1;
numgames ++;
if (numgames > 9){
numgames = 9;
lcd.setCursor(14,1);
lcd.print(numgames);
delay(300);
if (bButtonState == LOW) {
numgames --;
if (numgames < 1){
numgames = 1;
delay(300);
if (sButtonState == LOW && numgames > 0) {
game++;
Serial.print("Next step");
Serial.print(numgames);
Serial.print(sButtonState);
stopPrint = 0;
Serial.print("numgames = ");
Serial.print("gnum = ");
Serial.print(gnum);
void PreGame() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(".");
delay(300);
lcd.print(".");
delay(300);
lcd.print(".");
delay(300);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("PressBlackButton");
lcd.setCursor(0,1);
lcd.print("To Start Game ");
lcd.print(gnum);
stopPrint = 1;
delay(300);
if (sButtonState == LOW) {
//delaying until button pressed
Serial.print("pregame pressed");
game++;
lcd.clear();
lcd.setCursor(0,0);
stopPrint = 0;
void MainGame() {
Serial.print("Get Ready!\n");
lcd.print("Get Ready!");
Delay = random(100, 300);
//delaying a random time
delay(Delay*10);
//Checking for False Start
rForfeit = 1;
rDone = 1;
rForfeitCounter++;
bForfeit = 1;
bDone = 1;
bForfeitCounter++;
//STARTING!!!
digitalWrite(LightPin, HIGH);
game = game + gtype;
void OVRGAME() {
//counting time
if (timeDone == 0) {
delay(1);
time ++;
//checking if they're done!
if(rButtonState == LOW && rForfeit == 0 && rDone == 0) {
rDone = 1;
rTime = time;
rOvrTime = rOvrTime + rTime;
if(bButtonState == LOW && bForfeit == 0) {
bDone = 1;
bTime = time;
bOvrTime = bOvrTime + bTime;
//annoying processing thingy
if (rDone == 1 && bDone == 1) {
timeDone = 1;
Serial.print(time);
lcd.clear();
digitalWrite(LightPin, LOW);
Serial.print("processing.");
lcd.print("processing.");
Serial.print(".");
lcd.print(".");
Serial.print(".\n");
lcd.print(".");
lcd.clear();
//writing the time, or if they forfeited
if (rTime == 0) {
Serial.print("Red went too early\n");
lcd.print("R Forf ");
else {
Serial.print("Red time is: ");
lcd.print("R ");
Serial.print(rTime);
lcd.print(rTime);
Serial.print("ms\n");
lcd.print("ms ");
if (bTime == 0) {
Serial.print("Blue went too early\n");
lcd.print(" B Forf ");
else {
Serial.print("Blue time is: ");
lcd.print("B ");
Serial.print(bTime);
lcd.print(bTime);
lcd.print("ms");
delay(300);
//set cursor to second row
lcd.setCursor(0, 1);
lcd.print("RA ");
rAvg = rOvrTime/(gnum - rForfeitCounter) + rForfeitCounter * 10;
bAvg = bOvrTime/(gnum - bForfeitCounter) + bForfeitCounter * 10;
lcd.print(rAvg);
lcd.print("m BA ");
lcd.print(bAvg);
lcd.print("m");
stopPrint = 1;
delay(300);
game = game + 2;
stopPrint = 0;
void NUMOFWINSGAME() {
//counting time
delay(1);
time ++;
rDone = 1;
rTime = time;
rOvrTime = rOvrTime + time;
bDone = 1;
bTime = time;
bOvrTime = bOvrTime + time;
timeDone = 1;
if(stopPrint == 0) {
Serial.print(time);
lcd.clear();
Serial.print(".");
lcd.print(".");
lcd.print(".");
lcd.clear();
if (rTime == 0) {
else {
lcd.print("R ");
lcd.print(rTime);
lcd.print("ms ");
if (bTime == 0) {
else {
lcd.print("B ");
lcd.print(bTime);
lcd.print("ms");
delay(300);
//seeing who wins!
if (rTime == bTime && rForfeit == 0){
Serial.print("TIE\n");
lcd.print("TIE");
bWins++;
rWins++;
if (rTime == bTime && rForfeit == 1){
Serial.print("No-one wins\n");
lcd.print("Both Forfeited");
if (rTime < bTime && rForfeit == 0) {
Serial.print("RED WINS!!!\n");
lcd.print("RED WINS");
rWins++;
if(rTime < bTime && rForfeit == 1){
Serial.print("BLUE WINS!!!\n");
lcd.print("BLUE WINS");
bWins++;
if (bTime < rTime && bForfeit == 0) {
bWins++;
if(bTime < rTime && bForfeit == 1){
rWins++;
stopPrint = 1;
delay(300);
game ++;
stopPrint = 0;
void OVRResults() {
if (stopPrint == 0 && gtype == 1) {
lcd.clear();
lcd.setCursor(0,0);
if(rAvg > bAvg) {
lcd.print("rA = +");
lcd.print(rAvg - bAvg);
lcd.print("ms");
} else if(bAvg > rAvg) {
lcd.print("bA = +");
lcd.print(bAvg - rAvg);
lcd.print("ms");
lcd.print("r = b");
lcd.setCursor(0,1);
stopPrint = 1;
if (stopPrint == 0 && gtype == 2) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("RW = ");
lcd.print(rWins);
lcd.print(" BW = ");
lcd.print(bWins);
lcd.setCursor(0,1);
stopPrint = 1;
game++;
gnum++;
stopPrint = 0;
Serial.print(game);
void Restart() {
Serial.print("\ngnum = ");
Serial.print(gnum);
if (gnum > numgames) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Results");
lcd.clear();
if (gtype == 1) {
if (rAvg == bAvg){
lcd.print("TIE");
if (rAvg < bAvg) {
if (bAvg < rAvg){
lcd.setCursor(0,1);
lcd.print("r:");
lcd.print(rAvg);
lcd.print("ms b:");
lcd.print(bAvg);
lcd.print("ms");
if (gtype == 2) {
if (rWins == bWins){
lcd.print("TIE");
if (rWins < bWins) {
if (bWins < rWins){
lcd.setCursor(0,1);
lcd.print("rWins:");
lcd.print(rWins);
lcd.print(" bWins:");
lcd.print(bWins);
stopPrint = 1;
delay(300);
if(sButtonState == LOW){
stopPrint = 0;
bWins = 0;
rWins = 0;
rOvrTime = 0;
bOvrTime = 0;
gnum = 1;
numgames = 0;
game = 0;
gtype = 0;
rDone = 0;
bDone = 0;
rForfeit = 0;
bForfeit = 0;
time = 0;
rDone = 0;
bDone = 0;
rForfeit = 0;
bForfeit = 0;
time = 0;
timeDone = 0;
rTime = 0;
bTime = 0;
stopPrint = 0;
game = 2;
