SOLVED! Arduino Robot Not Responding/Bootloading/Uploading Problems
Recently I've got a new Arduino robot.
I followed the provided instructions and got the robot working well, however in the middle of operation the robot shuts off. I reset both motor and control boards but all it does is continuously go around in circles. I tried uploading some default sketches to the control board, they upload fine with no errors but the robot just keeps doing the same spinning motion. In the quick start guide it says that if the robot is behaving strangely the batteries might be low. I have recharged these batteries and also checked them to make sure they work but still I get the same problem.
I tried to re-upload the Robot_Motor_Core sketch to the motor board to see if that fixes it but still no luck.
I am very confused.
Specs:
MacBook (13 inch, Mid 2010)
Processor: 2.4 GHz Intel Core 2 Duo
Memory: 2GB 1067 MHz DDR3
OS: Mac OSX 10.8.4
Arduino Robot:
ATmega32u4
UPDATE:
I decided to get an USBASP programmer to reinstall the bootloaders for both boards, however I am able to burn the bootloader to the motor board with ease but not the control board.
I have the feeling that the control board is fried.
I get the error:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/ToaCarney/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : usbasp
avrdude: seen device from vendor ->www.fischl.de<-
avrdude: seen product ->USBasp<-
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
I looked this up with my programmer providers and they said that I need to activate the 'slow clock' feature on the programmer. I did this, but I get the same error.
So, to make it clear, my problem now is that I have no form of communication between my control board and my computer whatsoever. Both the USB connection or the USBASP programmer cannot communicate with the control board at all.
PS: After I burned the motor board bootloader the spinning that I was talking about in the previous post has stopped.
UPDATE:
I went into my terminal window and used the command: avrdude -p ATmega32U4 -c usbasp -v -F like the error suggests but I get the error:
avrdude: Version 6.0.1, compiled on Dec 16 2013 at 17:26:24
         System wide configuration file is "/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf"
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATmega32U4 is 1E 95 87
By the looks of it it looks like the ATmega32U4 is not responding to the programmer.
Any ideas?
Hi, what arduino do you have, what control board do you have.
Can you post a picture of your project and a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Did you check your wiring?
If you can upload other programs then you probably have no loading problems, have you tried the Blink program to see the on board Pin13 LED blink?
You said you tried to upload, but no luck, where was the failure.
Have you checked the parameters of your IDE if you cannot upload?
Tom....... :slight_smile:
Hi Tom,
Thank you for getting back.
Just to make it clear, I am not doing a project, I am trying to troubleshoot why The Arduino Robot (which is an official Arduino board) is not working correctly. I originally started this forum topic under Installation and Troubleshooting but I was moved to Project Guidance by a global moderator. I think because it was mistaken for a Project.
Here is some information anyway:
The Arduino itself is The Arduino Robot. LINK>>> http://arduino.cc/en/Main/Robot
The processor is the ATmega32U4.
NOTE: I am having trouble with the Control Board not the Motor Board on the Robot.
When I said I had no luck with uploading the Robot_Motor_Core sketch on the motor board. It meant that the robot still kept going around in circles even though the sketch in the control board dosen't even use the motors.
But now I have no form of communication between the computer and the Control board, so I can't upload anything to the control board anyway. I get the error:
         Using Port                    : /dev/cu.usbmodem411
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: ser_recv(): read error: Device not configured
When this problem first emerged I got no errors during upload but now I get the above error during upload.
I find it very bizarre.
SUCCESS!
AFTER LOOKING AT THIS PAGE http://arduino.cc/en/Guide/Robot#toc5 I JUST HAD TO DOUBLE TAP THE RESET BUTTON ON THE CONTROL BOARD WHILE UPLOADING A BLANK SKETCH.
I FEEL SO GREAT NOW. :slight_smile:
Hi, good stuff, now we all know.
Interesting fix.
Good to hear, have fun
Tom.... :slight_smile:
