I'm Seeking some help for my project... What's Happening: From various posts here, I learned that we can use the RX and TX lines of Arduino UNO as I/O ports.
But in order to work, I must disable every single call to Serial.begin, Serial.print, Serial.println, and related methods.
This is the problem: I'm doing it, but I still cannot reach a logic 0 in this port !!
I'm Basically doing a pulldown scheme with RX port (Exactly equal to this one here: http://www.mypetarduino.com/images/pullDownResistor.jpg), but all I can get is about 4.57v (Way above logic 0 of arduino) when the switch is open. My sketch (For test purposes) is the one below:
digitalWrite(0, LOW); // sets the LED off
pinMode(0, INPUT);
void loop() {}
I'm using a Shield that diminish the number of free ports from Arduino. All I got are 0,1,5 and 10 Digital ports... I also wanted 4 working buttons, so my only option (mantaining Arduino Uno my platform) was to try using D0 and D1.
Wire the button as a connection between the pin and ground. There is no need for a pull up resistor because the USB converter is doing that for you through a 1K resistor.
Thanks for your help! Consulting Arduino Uno Schematic Reference ((Here)), I managed to get 0v by grounding the pin, like Grumpy_Mike adviced. For either RX and TX, this solution works!
TomGeorge:
What shield are you using that uses all the pins?
Tom.....
I'm using a MP3 shield from Sparkfun. It occupy most of the pins, leaving some. But in my project several of the remainings were being used by an LCD display, leaving only four Digital ports.
