[SOLVED] Arduino uno: avrdude: ser_recv(): programmer is not responding
Hello,
after trying for one whole day to connect to an arduino, i managed to connect to an arduino uno over mkII at the ISP Header. There i installed the boot loader successfully. But if i try to upload a sketch threw the arduino ide, it always complains:
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Users/user/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/user/.avrduderc"
Using Port : /dev/tty.SeriellerAnschluss
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude done. Thank you.
Does someone know how i can bypass this nasty error?
regards
I figured it out: when i upload it from a terminal with avrdude, it is working flawless. This seems to be a problem within the arduino ide, which i experienced very often.
