Solved: Arduino Yun: Using SD- and FileIO-libs at the same time: Not possible?
Hi I’m trying to use FileIO to copy a .bmp-File from an Arduino Yun AR9331-connected SD-card to an SD card that is connected on the 32u4-side of the yun. However, as soon as I use SD.h (to talk to the SD-card on the 32u4-side) and FileIO.h (to talk to the AR9331 over the bridge), I get the following compiler-error:
In file included from tft_3_5_zoll_copy_bmp_from_ar9331_to_sd_and_display.ino:13:0:
/Applications/Arduino_1.5.7.app/Contents/Resources/Java/libraries/Bridge/src/FileIO.h:28:7: error: redefinition of ‘class File’
class File : public Stream {
In file included from tft_3_5_zoll_copy_bmp_from_ar9331_to_sd_and_display.ino:11:0:
/Applications/Arduino_1.5.7.app/Contents/Resources/Java/libraries/SD/src/SD.h:26:7: error: previous definition of ‘class File’
This is the source I’m trying to compile:
  Trying to copy a file from Yun's AR9331-SD to 32U4-SD
  over FileIO (Bridge).
#include <SPI.h>
#include <SD.h>
#include <Bridge.h>
#include <FileIO.h>
// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins.
#define SD_CS 4
File myFile;
void setup(void) {
  Bridge.begin(); // Noetig, damit die Console laeuft, man also ueber Internet etwas vom Arduino yun hoeren kann
  Serial.begin(57600);
  while(!Serial);
  pinMode(8, OUTPUT); // Hardware SS must be set to Output!
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS)) {
    Serial.println("failed!");
  Serial.println("OK!");
  if (SD.exists("test.bmp")) {
    SD.remove("test.bmp");
 Serial.println("Removing example.txt...");
  myFile = SD.open("test.bmp", FILE_WRITE);
  if (myFile){
  // Open requested file on SD card of AR9331
  File bmpFile = FileSystem.open("/mnt/sda1/bilder/75er/001.bmp");
  if (bmpFile == NULL) {
    Serial.println("File not found");
    return;
  else {
    Serial.println("File found");
  // Jetzt lesen wir die Daten via Bridge und schreiben Sie ins File.
  while (bmpFile.available()){
   myFile.write(bmpFile.read());
  myFile.close();
What could I do to circumvent this error? Do I have to rename one of the classes?
Thanks, Dani
Both SD.h and FileIO.h use a class that have the same name, so if you include them together you have that error. To use both libraries you can change the name of a class but you have to change the name everywhere the class is used. If you don't know what you have to modify you will encounter a lot of compilation errors.
Thanks for confirming my apprehension - I'll try it anyway! Dani
Ok, so if you want to use the Bridge library (FileSystem) to access files on the AR9331-side and copy them over to a SD-card on the 32u4 or teensy 3.1 side, you can use my altered Bridge library as attached below. It is a modified version of Paul Stoffregens general Bridge library as found at GitHub - PaulStoffregen/Bridge: Communicate between Teensy & Raspberry Pi - similar to Arduino Yun.
The following sketch copies a file from the linux side to the sd card on the arduino side:
  Copying a file from Yun's AR9331-SD to teensy3.1-SD
  Daniel Süsstrunk modified the already modified Arduino Yun
  Bridge by Paul Stoffregen to rename the class File to
  MyFile to avoid conflicts with the class File of the SD library.
#include <SPI.h>
#include <SD.h>
#include <Bridge.h>
#include <FileIO.h>
#define SD_CS 10
void setup(void) {
  Bridge.begin(); // Start bridge
  while(!Serial){;};
  Serial.println("Start");
  pinMode(SS, OUTPUT); // Hardware SS must be set to Output!
  else {
  File sdFile = SD.open("test.bmp", FILE_WRITE);
  // if the file opened okay, write to it:
  if (sdFile) {
    Serial.println("File opened ...");
    MyFile bmpFile = FileSystem.open("/mnt/sda1/bilderrahmen/bilder/75er/001.bmp");
      return;
    else {
    // Now read from the bridge and write to sdFile.
    	sdFile.write(bmpFile.read());
    sdFile.close();
    Serial.println("and closed");
    // if the file didn't open, print an error:
    Serial.println("error opening test.bmp");
I’m not used to tamper with libraries and if you see, that I did things the wrong way, please feel free to alter it and let me know here. Thanks!
Dani
Bridge.zip (134 KB)
