[SOLVED] arduino yun - wifi upload
Hello,
It's me and my yun again.
It seems that there is a problem uploading via wifi network.
Tried uploading the blink sketch via wifi. nothiing happens on the board.
Tried uploading it again via usd, it worked.
This is the message I got when uploaded via wifi.
arduino-builder/arduino-builder -compile -core-api-version 10611 -build-path /tmp/935380150 -hardwaarduino-builder/arduino-builder -compile -core-api-version 10611 -build-path /tmp/357376584 -hardware arduino-builder/hardware -hardware arduino-builder/packages/cores -tools arduino-builder/tools -tools arduino-builder/packages/tools -built-in-libraries arduino-builder/latest -libraries /tmp/605361485/pinned -libraries /tmp/605361485/custom -fqbn arduino:avr:yun -verbose=false /tmp/605361485/Blink
WARNING: Category '' in library ArduinoUnit is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library FlashStorage is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Parse Arduino SDK is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Pushetta is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SparkFun MG2639 CellShield is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library StereoSID is not valid. Setting to 'Uncategorized'
Unable to open file /tmp/sketch.hex for reading
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9587
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xD8"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xD8:
avrdude: load data hfuse data from input file 0xD8:
avrdude: input file 0xD8 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFB"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFB:
avrdude: load data efuse data from input file 0xFB:
avrdude: input file 0xFB contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "/tmp/sketch.hex"
avrdude: can't open input file /tmp/sketch.hex: No such file or directory
avrdude: read from file '/tmp/sketch.hex' failed
avrdude done. Thank you.
@puiucristian you are absolutely right! Even though the last message is 'avrdude done. Thank you.' the sketch is not correctly uploaded to the board, we will look into it ASAP
The wireless upload from the windows app works fine, if that helps.
We just deployed a new release and the problem with the network upload should be fixed now. Let us know if it works for you.
Thanks!
Great job guys, it works now.
avrdude: 32748 bytes of flash written
avrdude: verifying flash memory against /tmp/sketch.hex:
avrdude: load data flash data from input file /tmp/sketch.hex:
avrdude: input file /tmp/sketch.hex contains 32748 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 4.18s
avrdude: 32748 bytes of flash verified
