[SOLVED] Attiny84 and LCD16x2
Hey guys, I am going crazy here. Been googling for hours for a solution, but with no luck.
I am trying to get my LCD to work on an Attiny84A.
My Arduino is an Arduino UNO, and on top of it I have a Tinyldr 2.5 shield for programming other ICs.
I am trying to get the simple LCD tutorial to work.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
I read somewhere to try and insert a delay(1000); right before lcd.begin(); but that didn't help.
The datasheet for the chip can be found here: http://www.atmel.com/Images/doc8006.pdf
Now is it me who is missing something with those pins not being suitable for this or what am I doing wrong?
The code works on my Arduino UNO, and the Attiny84 works (testet with the Blink sketch).
I hope someone can help me :slight_smile:
EDIT: I have a pot connected correctly to the contrast of the display, but all I get is black boxes (vaguely cause I adjusted the contrast). Also pin R/W is connected to GND. The display I use is a DMC-16202NY-LY-BJE-BLN (http://www.digikey.com/product-detail/en/DMC-16202NY-LY-BJE-BLN/73-1346-ND/2242964)
Aaarh it totally hit me when reading the blink code. Pin 1 in arduino is not pin 1 on the IC >_<
Hi! i'm trying to make a project with attiny84 and i want to include an lcd. I've trying to connect that lcd to attiny84, i've changed the lcd pins on sketch but it's not working.
Would you share how do you manage to make it?
cheers!
Hi. I am also trying to program the Attiny84 with my Arduino to drive an LCD screen but I also just get dark blocks on the first line of the LCD. The sketch I have created works on the Arduino Uno but not the Attiny84. I have used pins (0,1,2,3,4,5) to connect to the LCD. Used the same pins with the UNO.
How did you manage to fix yours?
