[SOLVED]ATtiny85 @1MHz bootloader upload problem
I have been testing a library on a few ATtiny85 chips I purchased using the core at Google Code Archive - Long-term storage for Google Code Project Hosting.
With the exact same breadboard circuit and chip, using the ATtiny85 @ 16MHz I have no problem uploading either the bootloader (Fuse settings) nor then uploading my sketch; however, when I attempt to upload the ATtiny85 @ 1MHz bootloader I get the following error message:
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -pattiny85 -cstk500v2 -Pusb -e -Uefuse:w:0xFF:m -Uhfuse:w:0xD7:m -Ulfuse:w:0x62:m
avrdude: Version 5.11.1, compiled on Oct 30 2011 at 10:37:28
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
         User configuration file is "/home/wandrson/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 0000B0000204
avrdude: usbdev_open(): using read endpoint 0x82
avrdude: Sent: . [01]
avrdude: Recv: . [01] . [00] . [0a] A [41] V [56] R [52] I [49] S [53] P [50] _ [5f] M [4d] K [4b] 2 [32]
avrdude: stk500v2_getsync(): found AVRISP mkII programmer
         AVR Part                      : ATtiny85
         Chip Erase delay              : 4500 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      8192   64    128  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: AVRISP mkII
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [91]
avrdude: Sent: . [03] . [92]
avrdude: Recv: . [03] . [00] . [11]
         Hardware Version: 1
         Firmware Version Master : 1.17
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] 2 [32]
         Vtarget         : 5.0 V
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [03]
         SCK period      : 1.00 us
avrdude: Sent: . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00]
avrdude: Recv: . [10] . [00]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [00] . [00]
avrdude: Recv: . [1d] . [00] . [00] . [00] . [00] . [00] . [00]
avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [01] . [00]
################avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [02] . [00]
################################## | 100% 0.00s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
avrdude done.  Thank you.
The SCK delay is too short. Configure the programmer to go slower (1 M / 4 = max 250K bits per second).
