Hello, am new here, I am having difficulties getting my uploads to work, basically the simplest Blinky example, uploading to the attiny is fine however when i connect the LED, it does not blink, it stay HIGH all the time, in fact all pins light the LED. I have followed many tutorials online on getting arduino uno upload sketches via Arduino as ISP, am pretty sure with the connections, burnt bootloader, still to no avail. I have 5 ATTinys and all of them do the same, figured must be something with the Arduino IDE configuration or clock?
Attached below is the log, hoping this would help:
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/0k/rbh27rc10sj3tljyw7vtkg4w0000gn/T/AppTranslocation/BBC1C726-9989-4EAE-815D-63797B2EB525/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/hosnibona/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserial1d1140
Using Programmer : arduino
Overriding Baud Rate : 19200
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/var/folders/0k/rbh27rc10sj3tljyw7vtkg4w0000gn/T/arduino_build_143315/Blink_attiny.ino.hex"
avrdude: writing flash (682 bytes):
Writing | ################################################## | 100% 1.45s
avrdude: 682 bytes of flash written
avrdude: verifying flash memory against /var/folders/0k/rbh27rc10sj3tljyw7vtkg4w0000gn/T/arduino_build_143315/Blink_attiny.ino.hex:
avrdude: load data flash data from input file /var/folders/0k/rbh27rc10sj3tljyw7vtkg4w0000gn/T/arduino_build_143315/Blink_attiny.ino.hex:
avrdude: input file /var/folders/0k/rbh27rc10sj3tljyw7vtkg4w0000gn/T/arduino_build_143315/Blink_attiny.ino.hex contains 682 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.94s
avrdude: verifying ...
avrdude: 682 bytes of flash verified
avrdude done. Thank you.
Am using an Arduino Uno with latest Arduino IDE.
Note, i have gotten this to work the first time. Not sure why this is not working now.
I will try to upload picture or schematic if needed. Thanks guys
