following exactly from this page :http: //highlowtech.org/?p=1695
works, but the testing led blinking example flashed the led at more than 1 second, very long time interval. I think the clock or timer is wrong.
Did you do the Burn Bootloader step? If not the ATtiny is probably still set for the factory default speed of 1 MHz (8 MHz internal clock and prescale of 8). Your cycle time would then be eight seconds instead of one.
johnwasser:
didn't burn the Bootloader , but I tested it with 1mhz and 8mhz board options.
johnwasser:
thanks. burning bootloader with different clock speed board will set the time correctly for that speed board.
