[Solved] Bad mathematic with big number. old : Probleme modulo.
Hello,
I’m having some troubles while using % (modulo), but i think the probleme isn’t modulo. I’m wrong somewhere… And need help cause i’m not usual with c++.
[edit]Answer: The probleme was in the first line :
unsigned long long myTime = 233600000+401000;
should be :
unsigned long long myTime = 233600000UL+401000UL;
6v6gt:
If you are using unsigned long numbers eg 40000, you should write these with a following UL eg 40000UL to ensure these are not treated as ints.
Main
#include "Test.h"
//Init of the Object Instant
//with one hour and 1 sec, (total in millisecond).
unsigned long long myTime = 23*3600000+32*1000;
Instant instant = Instant(myTime);
  //moniteur serie
  unsigned long heure;
  int minute;
  int seconde;
  int milli;
  //Take back the time from Instant::getTime(int&,int&,int&,int&).
  instant.getTime(heure,minute,seconde,milli);
  Serial.println("Start");
  Serial.println(heure);
  Serial.println(minute);
  Serial.println(seconde);
  Serial.println(milli);
  delay(5000);
Test.cpp
#include "Test.h"
Instant::Instant(unsigned long long _millis) {
  totalMilli = _millis;
  UpdateTimeFromMillis();
void Instant::getTime(unsigned long &_heure,int &_minute,int &_seconde,int &_milli){
  _heure = heure;
  _minute = minute;
  _seconde = seconde;
  _milli = milli;
void Instant::UpdateTimeFromMillis(){
  heure = totalMilli/1000/60/60%24;
  minute = totalMilli/1000/60%60;
  seconde = totalMilli/1000%60;
  milli = totalMilli%1000;
Test.h
#ifndef Test_H
#define Test_H
class Instant {
  public:
    Instant(unsigned long long _millis);
    void getTime(unsigned long &_heure,int &_minute,int &_seconde,int &_milli);
    private:
    int minute;
    int seconde;
    int milli;
    unsigned long long totalMilli;
    void UpdateTimeFromMillis();
    void UpdateTimeFromHMS();
#endif
Output OK :
Start
23
0
32
0
This code work… But if (in main, first lign) i do :
//this won't work :
myTime = 24*3600000+32*1000;
//output :
//0
//0
//32
//0
//this won't work :
myTime = 25*3600000+32*1000;
//output :
//1
//0
//32
//0
//this won't work :
myTime = 26*3600000+32*1000;
//output :
//2
//0
//32
//0
As you can see the number of hour is something like reset at 24. But that’s not the same for secondes :
//this won't work :
myTime = 23*3600000+33*1000;
//output :
//22
//59
//27
//464
I think there is something i don’t understand, maybe in the “UpdateTimeFromMillis()”.
  minute = totalMilli/1000/60%60;What is the order of precedence in that calculation (and others) ? Will the modulo calculation be done at the end of the calculation or at the beginning ? If the latter then 60%60 will always be zero.
The modulo is done after the rest, else the code shouldn't work at all and it work (with not to high value.)
Well... while i copy my code and make it shorter for this forum, i didn't add days possibility, but i forgot to delete %24 at hour line. The probleme stay the same.
After some more try, i think a probleme is in the first line : if i do:
unsigned long long myTime = 0*3600000+40*1000;
i got some random answer... but if i do :
Instant instant = Instant(40000);
That work, so the probleme is in myTime, maybe the "*" caracter is show as hexadecimal or something like this.
If you have doubts about the execution order of operators, use brackets ( ) to force the order.
What value do you get in myTime?
An enormous value (in milliseconde), i cannot directly log it but that represent:
3050584830 days
14 hour
25 min
26 sec
80 millisec
I can see a "warning: integer overflow in expression" soo maybe that is not the correct answer.
Perfect, that solved the problem, can i have more details about that (or a link)?
Thank you all for your fast answers.
Take your pick: https://www.google.ch/?gws_rd=ssl#newwindow=1&q=C%2B%2B+UL+literal+type+suffix
