[solved] Basic code not working
Hello everyone !
I recieved my first Arduino yesterday. I'm very new to electronic and prgoramming but it appears that this wonderful device is very easy to play with.
So I started my little project. It's an ultra simple game using a button, 6LEDs (3 reds, 3 greens, along with the resistors) and a speaker (not used for now, will be used later to play a little music.
The idea is pretty simple : When the button is pushed, the Arduino choose a random number between 0 and 1. If the number is equal to 0, you lose so the 3 red LEDs will flash ; if the number is something else, you won so the 3 green LEDs will flash.
The only difficulty I had was to know how to choose a random number, I simply read the documentation for that.
But my device isn't working. If it works when I loose (apparently, because sometimes red LEDs are flashing when I push the button) it seems that the win condition isn't working at all (I never saw the green LEDs flashing, plus sometimes nothing happens when I push the button).
Here is my code, I think how I build my board is pretty obvious only by reading the code, but if you need it I'll post a photo of it.
const int ledPins[] = {2,3,4,5,6,7};
const int buttonPin = 9;
int buttonState = 0;
int randNumber;
void win() {
  digitalWrite(ledPins[3], HIGH);
  digitalWrite(ledPins[4], HIGH);
  digitalWrite(ledPins[5], HIGH);
void lose() {
  digitalWrite(ledPins[0], HIGH);
  digitalWrite(ledPins[1], HIGH);
  digitalWrite(ledPins[2], HIGH);
  for(int i = 0; i < 6; i++){ pinMode(ledPins[i], OUTPUT);}
  pinMode(buttonPin, INPUT);
  digitalWrite (buttonPin, HIGH); //suggested by Groove
  randomSeed(analogRead(0));
  if (digitalRead(buttonPin) == LOW) {
    randNumber = random(2); // Select a random number from 0 to 1. Fixed by Groove
    if (randNumber == 0) {
      lose();
    } else { win(); }
    while (digitalRead(buttonPin) == LOW) {/*WAIT FOR A RELEASE*/} // suggested by AlphaBeta
Thank you very much in advance for your answers !
Do you have a pull-up resistor on the button?
You should.
BTW, no need for a "pinMode" in "loop()"
Thanks for your reply !
Yes, the button have a pull-up resistor, I borrowed everything from what I've learned from the oomlout's tutorials.
Unfortunately, your correction doesn't change a thing. Besides I didn't really understood why I had to add a digitalWrite for the button ; what was you idea ?
Thanks for the correction of pinMode in loop(), I didn't noticied it.
Try
    randNumber = random(1); // Select a random number from 0 to 1
      lose();
    } else { win(); }
:slight_smile:
Thank you very much AlphaBeta, but your suggestion doesn't seems to change anything either. :-[
However, if I don't misunderstand, this line is useful to re-run the program several times by releasing and pushing the button again ?
"digitalWrite" on a pin declared as an input enables or disables the AVR's internal pull-up resistor - an external resistor isn't necessary.
Correction: "// Select a random number that is always zero."
"max - upper bound of the random value, exclusive"
Indeed ! That fixed the problem !
I had some doubts about it ineed. So now random(1) has been replaced by random(2).
Thank you very much again ! :slight_smile:
