Hi! So I am creating a robot using Bluetooth and processing, and I am having an issue. The Bluetooth receives the signal properly and moves the servos/motors accordingly, but aside from that all of the servos will just start spazzing. There's no clear reason for this, as when I tested it through the regular serial connection it was just fine. Just some background, the Arduino is supposed to take a code and deconstruct the string in order to control a motor/servo. For example, ""; "<" and ">" signify the start and end of the message. The "B" tells the program which motor/servo to control, and the "200" signifies the speed/mapping of the servo/motor. The reason this is necessary is that I have a Processing code running in the background taking inputs from my controller and sending mapping data over the Serial port. The "Claw" servo seems to work at the beginning where I map it so that it does not stall at the close, but completely stops working after that. Does anyone have any idea why that might be? Any help would be appreciated.
Arduino 1st Tab:
#include <Wire.h>
#include <Servo.h>
#include <Adafruit_MotorShield.h>
#include <SoftwareSerial.h>
SoftwareSerial hc06(2,3);
//set up motorhsield
Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x60);
//assign motors
Adafruit_DCMotor *RailMotor = AFMS.getMotor(1);
Adafruit_DCMotor *Swivel = AFMS.getMotor(2);
Adafruit_DCMotor *Screw = AFMS.getMotor(3);
//call the servo library
Servo DrillArm, ClawArm, Claw, Elbow;
const byte number_of_chars = 32;
char receivedChars[number_of_chars];
boolean new_data = false;
hc06.begin(9600);
// create with the default frequency 1.6KHz
AFMS.begin();
//assign servos
Elbow.attach(12);
DrillArm.attach(11);
ClawArm.attach(10);
Claw.attach(9);
Claw.write(75);
receivePacket();
if (new_data == true) {
parseData();
executeParsedData();
new_data = false;
char buf[4] = {receivedChars[1], receivedChars[2], receivedChars[3], receivedChars[4]};
int mapp = atoi(buf);
if (receivedChars[0] == 'A'){ //claw arm control
ClawArm.write(mapp);
else if(receivedChars[0] == 'B'){ //elbow control
Elbow.write(mapp);
else if(receivedChars[0] == 'C'){ //claw open or close
Claw.write(mapp);
else if(receivedChars[0] == 'D'){ //drill arm control
DrillArm.write(mapp);
else if(receivedChars[0] == 'E'){ //rail control
if (mapp > 20){
RailMotor->setSpeed(mapp);
RailMotor->run(FORWARD);
else if (mapp < -20){
RailMotor->setSpeed(abs(mapp));
RailMotor->run(BACKWARD);
else {
RailMotor->run(RELEASE);
else if(receivedChars[0] == 'F'){ //swivel control
if (mapp > 15){
Swivel->setSpeed(mapp);
Swivel->run(FORWARD);
else if (mapp < -15){
Swivel->setSpeed(abs(mapp));
Swivel->run(BACKWARD);
else {
Swivel->run(RELEASE);
else if(receivedChars[0] == 'G'){ //screw control
if (mapp > 15){
Screw->setSpeed(mapp);
Screw->run(FORWARD);
Screw->setSpeed(abs(mapp));
Screw->run(BACKWARD);
else {
Screw->run(RELEASE);
Arduino 2nd Tab:
#include <Wire.h>
int red_led = 3;
int green_led = 6;
int blue_led = 5;
int int_1 = 0;
int int_2 = 0;
int int_3 = 0;
void receivePacket() {
digitalWrite(LED_BUILTIN, LOW);
static boolean receiving = false;
static byte index = 0;
char start_mark = '<';
char end_mark = '>';
char rc;
while (hc06.available() > 0 && new_data == false) {
rc = hc06.read();
if (receiving == true) {
if (rc != end_mark) {
receivedChars[index] = rc;
index++;
if (index >= number_of_chars) {
index = number_of_chars-1;
receivedChars[index] = '\0';
receiving = false;
index = 0;
new_data = true;
} else if (rc == start_mark) {
receiving = true;
void parseData() {
char * split;
split = strtok(receivedChars, ",");
int_1 = atoi(split);
split = strtok(NULL, ",");
int_2 = atoi(split);
int_3 = atoi(split);
void executeParsedData() {
if (int_3 == 0) {
analogWrite(red_led, 0);
analogWrite(green_led, 0);
analogWrite(blue_led, 0);
} else if (int_3 == 1) {
analogWrite(red_led, 255);
analogWrite(green_led, 255);
analogWrite(blue_led, 255);
} else if (int_3 == 2) {
if (int_2 == 0) analogWrite(red_led, int_1);
if (int_2 == 1) analogWrite(green_led, int_1);
if (int_2 == 2) analogWrite(blue_led, int_1);
Processing:
import processing.serial.*;
import net.java.games.input.*;
import org.gamecontrolplus.*;
import org.gamecontrolplus.gui.*;
Serial port;
ControlDevice cont;
ControlIO control;
float swivel, screw, rail, selectcontrol;
boolean shoulderselect, elbowselect, clawarmselect, clawgrab, clawrelease;
String portmessage, string;
PImage splash;
void setup(){
size(700, 400);
control = ControlIO.getInstance(this);
cont = control.getMatchedDevice("STAR_2021_Artificial_Astronauts_controls");
if (cont == null) {
println("No suitable device configured, exiting program");
System.exit(-1);
splash = loadImage("Artificial Astronaut Control Scheme");
println((Object[])Serial.list());
port = new Serial(this, "COM5", 9600);
public void getUserInput() {
screw = map(cont.getSlider("Screw").getValue(), -1, 1, 0, 180);
swivel = map(cont.getSlider("SwivelJoint").getValue(), -1, 1, 0, 180);
rail = map(cont.getSlider("Rail").getValue(), -1, 1, 0, 180);
selectcontrol = map(cont.getSlider("SelectControl").getValue(), -1, 1, 0, 360);
shoulderselect = cont.getButton("ShoulderSelect").pressed();
elbowselect = cont.getButton("ElbowSelect").pressed();
clawarmselect = cont.getButton("ClawArmSelect").pressed();
clawgrab = cont.getButton("ClawGrab").pressed();
clawrelease = cont.getButton("ClawRelease").pressed();
void draw() {
getUserInput();
background(selectcontrol,400,400);
//send a list that consists of the joint's name and, position(and direction) to the serial for the arduino
if(clawarmselect){ //control claw arm with right stick
println("Selecting the claw arm to control, use the right stick to control");
portmessage = "<A"+str((int)selectcontrol/2)+">";
port.write(portmessage);
clawarmselect = false;
if(elbowselect){ //control elbow with button and control right stick
println("Selecting the elbow to control, use the right stick to control: ");
portmessage = "<B"+str(((int)selectcontrol/2))+">";
print(portmessage);
elbowselect = false;
if(clawgrab){ //close claw
println("Claw Closing");
port.write("<C75>");
clawgrab = false;
if(clawrelease){ //open claw
println("Claw Opening");
port.write("<C0>");
clawrelease = false;
if(shoulderselect){ //control elbow with button and control right stick
println("Selecting the shoulder to control, use the right stick to control: ");
portmessage = "<D"+str((int)selectcontrol)+">";
shoulderselect = false;
if(rail > 105 | rail < 80){ //control elbow with button and control right stick
println("Selecting the rail to control, use the left stick to control: ");
portmessage = "<E"+str((int)rail)+">";
print(portmessage);
if(swivel > 105 | swivel < 80){ //control swivel with button and control right stick
println("Selecting the swivel to control, use the left stick to control: ");
portmessage = "<F"+str(((int)swivel))+">";
print(portmessage);
if(screw > 105 | screw < 75){ //control screw with trigger buttons, right trigger goes to -1, left goes to 1
println("Screw: ");
portmessage = "<G"+str((int)screw-90)+">";
print(portmessage);
