[ solved ]Break down two digits, to one Digit.
I am using this clock function on LCD Display [lcd.print(now.minutes (), DEC);], When this compute and spits out on the serial line of the Arduino the line reads 15. I want to use if statement and read to two digits together or just the Single digit. Is there a way I can do digit trap with Arduino. So it can read the 15 or just the 5 Data.
[lcd.print(now.minutes(), DEC);] = 15
//( this if statement all I want to do is read the two digits 15 )
If ((lcd.print(now.minutes(), DEC) =< 10)
Do this
[lcd.print(now.minutes(), DEC);] = 05
//( this if statement all I want to do is read the one digit 5 )
If ((lcd.print(now.minutes(), DEC) =< 5)
Do this
[\code]
15 % 10 == 5 15 / 10 % 10 == 1
Additional hint: what you print is the result of the function call now.minutes() which returns most likely a uint8_t --> that's a number.
then you can apply what @MarkT is suggesting
should be faster than division via lookup table but code size will be bigger or if else for smaller code size without division. only for 2 digit decimals.
unsigned char number=0;
unsigned char second_number=0;
unsigned char first_number=0;
  second_number = number % 10;
  number -= second_number;
  switch (number) {
    case 10: case 20: case 30:
      first_number = number >> 3;
    case 40:
      first_number = number - 1 >> 3;
    case 50:
      first_number = number - 10 >> 3;
    default:
      first_number = number - 11 >> 3;
MarkT and J-M-L both your solutions worked excellent thank you for the time and the data.
