[Solved] Bresser 7002000 weather station sensor decoding riddle
There are no DIP switches, on the inside there is only a reset button next to the batteries - nothing more.
Miq1:
It must be something simple - I would not expect the tiny brain of the sensor doing something elaborate.
Yes the initial flurry of bits is to settle the AGC of a receiver, you normally then have a random number of undetermined bit length that is generated when the sensor is powered.
You will obviously have temperature and humidity values, possible channel number (if your device supports this) and maybe battery condition. This may be topped of with a CRC or checksum.
I have seen different ways of doing the temperature. Some just use signed values of the temperature, multiplied to remove decimal point. Some add an offset to the temperature so (for example) -10.0C would transmit as zero, 20.0C transmits as 300.
Yes, the offset is done with other Bresser sensors as well. They even are using Fahrenheit values instead of Celsius, plus an offset of 90 degrees. I would concentrate first on the humidity, as that will be encoded as a single byte most probably.
In my Manchester lib (I know this here is PWM, not Manchester ;)) there is another technique applied: a "decoupling mask". Any data byte is first XORed with a 8-bit mask of 11001010b before being sent. May be something similar is used here, but I was not able to find one yet. I tried to XOR the bit pattern of a humidity value against the received data, apply the resulting mask (if there was one) with XOR to another message at the same spot to see if the resulting bit sequence would result into the humidity value for that second message.
But unfortunately I did not find a match in the last 16 bits - I stopped there since I did it manually and got tired noting down bits :smiley:
One more consideration: I think we can omit looking for float values, as the simplest binary form (IEEE754) will have 32 bits for a single value - too many to fit in the short message. So it will be a shorter, binary format.
I opened the sensor to look for the PCB; the sensor is a Sensirion SHTC1
It delivers temperature and humidity via I²C in 24 bit packets (MSB, LSB and Checksum). The real value is calculated as (MSB,LSB)/65536, so "10100001,00110011,00011100" gets 62.9% and "01100100,10001011,11000111" 23.7°C.
But even these bit sequences are not identifyable in the messages. 63% (displayed) would be something around "10100001,01xxxxxx" - this sequence is in fact in the sampled data ("10100001,11101001") and will result in 63.24%. But the next line had "10100000,01101001" at the same spot, that is a lower value (62,66%), while a higher (65%) was displayed.
In general the numbers at that spot are close to 62%-63%, whereas the displayed values range from 57% to 65%.
Miq1:
I have never see floats used in these types of sensor. As mentioned in #21 the value is normally multiplied to remove the decimal point (fraction) and then divided again after reception.
Miq1:
Very unlikely the MCU in the sender would transmit raw data. The sensor info is helpful as it gives the min/max temperature & humidity ranges so we now know the temperature ranges from -30 to +100 and humidity the obvious 0-100%.
Assuming they allow for the full range then to send -30 using unsigned integers means they mast add 300 or 3000 (depending on number of decimal places the sensor works with) to the multiplied temperature.
From the image you posted in #14 I see the data as one of these…
111111111111111100111011110011000111010110100001110000110110101111
000000000000000011000100001100111000101001011110001111001001010000
but without having the temperature & humidity values it is impossible to find meaningful data.
I put the sensor in the freezer for a while and captured a good hour of data while it was warming up again. Thus I got data for negative temperatures as well now. I missed two messages around 30 minutes after beginning that were scrambled by a parallel transmission from somewhere else.
I generated two data sets, one for regular and one for inverted bits in CSV format:
17:04:59;1111111111111110011101110010010010101111010000011100011011000111;-6.0;32;
17:06:28;1111111111111110011101110011110100101111010000101100011010100111;-6.0;35;
17:07:57;1111111111111110011101110011110100101111010000010100011001000111;-3.7;47;
17:09:26;1111111111111110011101110000010001101111010000000101101010100111;-0.2;58;
17:10:55;1111111111111110011101110010110111101111010000111000101010110111;1.5;65;
17:12:24;1111111111111110011101111001010011101111010000010101001010110111;3.6;69;
17:13:53;1111111111111110011101111010010001101111010000011001001000000111;5.4;72;
17:15:22;1111111111111110011101111011010010101111010000101100001001110111;6.8;74;
17:16:51;1111111111111110011101111011100100101111010000110100001011100111;8.0;75;
17:18:20;1111111111111110011101111011110111001111010000010100001000000111;9.0;75;
17:19:49;1111111111111110011101111011110011001111010000010100001010000111;10.0;75;
17:21:18;1111111111111110011101111011110111100111010000010100001010010111;10.8;75;
17:22:47;1111111111111110011101111011100111100111010000010100001010000111;11.6;73;
17:24:16;1111111111111110011101111010010011100111010000001100001000010111;12.4;72;
17:25:45;1111111111111110011101111011010101100111010000101100001000010111;13.0;70;
17:27:14;1111111111111110011101111011110001100111010000111100001011110111;13.6;69;
17:28:43;1111111111111110011101111010010001100111010000011001001010000111;14.2;68;
17:30:12;1111111111111110011101111010110110100111010000111001001011000111;14.8;66;
17:33:10;1111111111111110011101111000110010100111010000010101001001110111;15.8;64;
17:36:08;1111111111111110011101111000110100100111010000101101001001010111;16.7;62;
17:37:37;1111111111111110011101111000010100100111010000101101001001110111;17.1;60;
17:39:06;1111111111111110011101111001110000100111010000111101001011010111;17.4;59;
17:40:35;1111111111111110011101111011010000100111010000011000101000100111;17.7;59;
17:42:04;1111111111111110011101111000010000100111010000011000101011100111;18.0;58;
17:43:33;1111111111111110011101111011110111000111010000111000101001110111;18.3;57;
17:45:02;1111111111111110011101111000110111000111010000000100101001000111;18.6;57;
17:46:31;1111111111111110011101111010010111000111010000000100101011100111;18.8;56;
17:48:00;1111111111111110011101111011100111000111010000100100101000010111;19.0;55;
17:49:29;1111111111111110011101111011110011000111010000010100101001000111;19.2;54;
17:50:58;1111111111111110011101111010110011000111010000110100101010000111;19.4;54;
17:52:27;1111111111111110011101111011010011000111010000110100101011100111;19.6;53;
17:53:56;1111111111111110011101111010010011000111010000001100101001000111;19.7;53;
17:55:25;1111111111111110011101111000010011000111010000001100101011000111;19.9;52;
17:56:54;1111111111111110011101111001100011000111010000101100101000110111;20.0;52;
17:58:23;1111111111111110011101111011110111101011010000101100101011110111;20.1;52;
17:59:52;1111111111111110011101111001110111101011010000101100101001110111;20.2;51;
18:01:21;1111111111111110011101111010110111101011010000011100101001110111;20.4;51;
18:02:50;1111111111111110011101111011010111101011010000011100101000010111;20.5;51;
18:04:19;1111111111111110011101111001010111101011010000011100101010010111;20.6;50;
18:05:48;1111111111111110011101111010010111101011010000111100101011010111;20.6;50;
18:07:17;1111111111111110011101111010010111101011010000111100101011010111;20.8;50;
18:08:46;1111111111111110011101111011100111101011010000111100101010100111;20.8;49;
18:10:15;1111111111111110011101111011100111101011010000011001101010110111;20.9;49;
18:11:44;1111111111111110011101111001100111101011010000011001101000110111;21.0;49;
18:13:13;1111111111111110011101111011110011101011010000011001101000100111;21.0;49;
18:14:42;1111111111111110011101111011110011101011010000011001101000100111;21.1;48;
18:16:11;1111111111111110011101111001110011101011010000111001101000100111;21.2;48;
And the inverted one:
17:04:59;0000000000000001100010001101101101010000101111100011100100111000;-6.0;32;
17:06:28;0000000000000001100010001100001011010000101111010011100101011000;-6.0;35;
17:07:57;0000000000000001100010001100001011010000101111101011100110111000;-3.7;47;
17:09:26;0000000000000001100010001111101110010000101111111010010101011000;-0.2;58;
17:10:55;0000000000000001100010001101001000010000101111000111010101001000;1.5;65;
17:12:24;0000000000000001100010000110101100010000101111101010110101001000;3.6;69;
17:13:53;0000000000000001100010000101101110010000101111100110110111111000;5.4;72;
17:15:22;0000000000000001100010000100101101010000101111010011110110001000;6.8;74;
17:16:51;0000000000000001100010000100011011010000101111001011110100011000;8.0;75;
17:18:20;0000000000000001100010000100001000110000101111101011110111111000;9.0;75;
17:19:49;0000000000000001100010000100001100110000101111101011110101111000;10.0;75;
17:21:18;0000000000000001100010000100001000011000101111101011110101101000;10.8;75;
17:22:47;0000000000000001100010000100011000011000101111101011110101111000;11.6;73;
17:24:16;0000000000000001100010000101101100011000101111110011110111101000;12.4;72;
17:25:45;0000000000000001100010000100101010011000101111010011110111101000;13.0;70;
17:27:14;0000000000000001100010000100001110011000101111000011110100001000;13.6;69;
17:28:43;0000000000000001100010000101101110011000101111100110110101111000;14.2;68;
17:30:12;0000000000000001100010000101001001011000101111000110110100111000;14.8;66;
17:33:10;0000000000000001100010000111001101011000101111101010110110001000;15.8;64;
17:36:08;0000000000000001100010000111001011011000101111010010110110101000;16.7;62;
17:37:37;0000000000000001100010000111101011011000101111010010110110001000;17.1;60;
17:39:06;0000000000000001100010000110001111011000101111000010110100101000;17.4;59;
17:40:35;0000000000000001100010000100101111011000101111100111010111011000;17.7;59;
17:42:04;0000000000000001100010000111101111011000101111100111010100011000;18.0;58;
17:43:33;0000000000000001100010000100001000111000101111000111010110001000;18.3;57;
17:45:02;0000000000000001100010000111001000111000101111111011010110111000;18.6;57;
17:46:31;0000000000000001100010000101101000111000101111111011010100011000;18.8;56;
17:48:00;0000000000000001100010000100011000111000101111011011010111101000;19.0;55;
17:49:29;0000000000000001100010000100001100111000101111101011010110111000;19.2;54;
17:50:58;0000000000000001100010000101001100111000101111001011010101111000;19.4;54;
17:52:27;0000000000000001100010000100101100111000101111001011010100011000;19.6;53;
17:53:56;0000000000000001100010000101101100111000101111110011010110111000;19.7;53;
17:55:25;0000000000000001100010000111101100111000101111110011010100111000;19.9;52;
17:56:54;0000000000000001100010000110011100111000101111010011010111001000;20.0;52;
17:58:23;0000000000000001100010000100001000010100101111010011010100001000;20.1;52;
17:59:52;0000000000000001100010000110001000010100101111010011010110001000;20.2;51;
18:01:21;0000000000000001100010000101001000010100101111100011010110001000;20.4;51;
18:02:50;0000000000000001100010000100101000010100101111100011010111101000;20.5;51;
18:04:19;0000000000000001100010000110101000010100101111100011010101101000;20.6;50;
18:05:48;0000000000000001100010000101101000010100101111000011010100101000;20.6;50;
18:07:17;0000000000000001100010000101101000010100101111000011010100101000;20.8;50;
18:08:46;0000000000000001100010000100011000010100101111000011010101011000;20.8;49;
18:10:15;0000000000000001100010000100011000010100101111100110010101001000;20.9;49;
18:11:44;0000000000000001100010000110011000010100101111100110010111001000;21.0;49;
18:13:13;0000000000000001100010000100001100010100101111100110010111011000;21.0;49;
18:14:42;0000000000000001100010000100001100010100101111100110010111011000;21.1;48;
18:16:11;0000000000000001100010000110001100010100101111000110010111011000;21.2;48;
I found the lines most interesting where the displayed values were identical - nevertheless the transmitted data is slightly different there. It seems the precision in the messages is higher than that displayed.
There were two regions affected when only the temperature changed, so I would take for granted there is some kind of checksum at the end of the binary data.
Once again I had to drop down the reading to make them match better with the data.
<Sync----------> <Head---> aaaa bbbb cccc dddd eeee ffff gggg hhhh iiii <Tail <Temp       <Hum      <Bin     <Bin Inverted
0000000000000001 1000 1000 1101 1011 0101 0000 1011 1110 0011 1001 0011 1000
0000000000000001 1000 1000 1100 0010 1101 0000 1011 1101 0011 1001 0101 1000  -6.0        32 (0x20)
0000000000000001 1000 1000 1100 0010 1101 0000 1011 1110 1011 1001 1011 1000  -6.0        35 (0x23)
0000000000000001 1000 1000 1111 1011 1001 0000 1011 1111 1010 0101 0101 1000  -3.7        47 (0x2F)
0000000000000001 1000 1000 1101 0010 0001 0000 1011 1100 0111 0101 0100 1000  -0.2        58 (0x3A)
0000000000000001 1000 1000 0110 1011 0001 0000 1011 1110 1010 1101 0100 1000   1.5        65 (0x41)
0000000000000001 1000 1000 0101 1011 1001 0000 1011 1110 0110 1101 1111 1000   3.6        69 (0x45)
0000000000000001 1000 1000 0100 1011 0101 0000 1011 1101 0011 1101 1000 1000   5.4        72 (0x48)
0000000000000001 1000 1000 0100 0110 1101 0000 1011 1100 1011 1101 0001 1000   6.8        74 (0x4A)
0000000000000001 1000 1000 0100 0010 0011 0000 1011 1110 1011 1101 1111 1000   8.0        75 (0x4B)
0000000000000001 1000 1000 0100 0011 0011 0000 1011 1110 1011 1101 0111 1000   9.0        75 (0x4B)
0000000000000001 1000 1000 0100 0010 0001 1000 1011 1110 1011 1101 0110 1000  10.0        75 (0x4B)
0000000000000001 1000 1000 0100 0110 0001 1000 1011 1110 1011 1101 0111 1000  10.8        75 (0x4B)
0000000000000001 1000 1000 0101 1011 0001 1000 1011 1111 0011 1101 1110 1000  11.6        73 (0x49)
0000000000000001 1000 1000 0100 1010 1001 1000 1011 1101 0011 1101 1110 1000  12.4        72 (0x48)
0000000000000001 1000 1000 0100 0011 1001 1000 1011 1100 0011 1101 0000 1000  13.0        70 (0x46)
0000000000000001 1000 1000 0101 1011 1001 1000 1011 1110 0110 1101 0111 1000  13.6        69 (0x45)
0000000000000001 1000 1000 0101 0010 0101 1000 1011 1100 0110 1101 0011 1000  14.2        68 (0x44)
0000000000000001 1000 1000 0111 0011 0101 1000 1011 1110 1010 1101 1000 1000  14.8        66 (0x42)
0000000000000001 1000 1000 0111 0010 1101 1000 1011 1101 0010 1101 1010 1000  15.8        64 (0x40)
0000000000000001 1000 1000 0111 1010 1101 1000 1011 1101 0010 1101 1000 1000  16.7        62 (0x3E)
0000000000000001 1000 1000 0110 0011 1101 1000 1011 1100 0010 1101 0010 1000  17.1        60 (0x3C)
0000000000000001 1000 1000 0100 1011 1101 1000 1011 1110 0111 0101 1101 1000  17.4        59 (0x3B)
0000000000000001 1000 1000 0111 1011 1101 1000 1011 1110 0111 0101 0001 1000  17.7        59 (0x3B)
0000000000000001 1000 1000 0100 0010 0011 1000 1011 1100 0111 0101 1000 1000  18.0        58 (0x3A)
0000000000000001 1000 1000 0111 0010 0011 1000 1011 1111 1011 0101 1011 1000  18.3        57 (0x39)
0000000000000001 1000 1000 0101 1010 0011 1000 1011 1111 1011 0101 0001 1000  18.6        57 (0x39)
0000000000000001 1000 1000 0100 0110 0011 1000 1011 1101 1011 0101 1110 1000  18.8        56 (0x38)
0000000000000001 1000 1000 0100 0011 0011 1000 1011 1110 1011 0101 1011 1000  19.0        55 (0x37)
0000000000000001 1000 1000 0101 0011 0011 1000 1011 1100 1011 0101 0111 1000  19.2        54 (0x36)
0000000000000001 1000 1000 0100 1011 0011 1000 1011 1100 1011 0101 0001 1000  19.4        54 (0x36)
0000000000000001 1000 1000 0101 1011 0011 1000 1011 1111 0011 0101 1011 1000  19.6        53 (0x35)
0000000000000001 1000 1000 0111 1011 0011 1000 1011 1111 0011 0101 0011 1000  19.7        53 (0x35)
0000000000000001 1000 1000 0110 0111 0011 1000 1011 1101 0011 0101 1100 1000  19.9        52 (0x34)
0000000000000001 1000 1000 0100 0010 0001 0100 1011 1101 0011 0101 0000 1000  20.0        52 (0x34)
0000000000000001 1000 1000 0110 0010 0001 0100 1011 1101 0011 0101 1000 1000  20.1        52 (0x34)
0000000000000001 1000 1000 0101 0010 0001 0100 1011 1110 0011 0101 1000 1000  20.2        51 (0x33) 00110011 (11001100)
0000000000000001 1000 1000 0100 1010 0001 0100 1011 1110 0011 0101 1110 1000  20.4        51 (0x33)
0000000000000001 1000 1000 0110 1010 0001 0100 1011 1110 0011 0101 0110 1000  20.5        51 (0x33)
0000000000000001 1000 1000 0101 1010 0001 0100 1011 1100 0011 0101 0010 1000  20.6        50 (0x32)
0000000000000001 1000 1000 0100 0110 0001 0100 1011 1100 0011 0101 0101 1000  20.8        50 (0x32)
0000000000000001 1000 1000 0100 0110 0001 0100 1011 1110 0110 0101 0100 1000  20.8        49 (0x31) 00110001 (11001110)
0000000000000001 1000 1000 0110 0110 0001 0100 1011 1110 0110 0101 1100 1000  20.9        49 (0x31)
0000000000000001 1000 1000 0100 0011 0001 0100 1011 1110 0110 0101 1101 1000  21.0        49 (0x31)
0000000000000001 1000 1000 0110 0011 0001 0100 1011 1100 0110 0101 1101 1000  21.1        48 (0x30)
        21.2        48 (0x30)
Data column ffff is definitely to do with humidity and I think eeee is probably the other part but I have not figured out the encoding yet.
dddd is related to temperature as it changes every time the temperature changes by 10 degrees (0x.x, 1x.x, 2x.x etc) It seems to be binary nibble of tens of degrees expressed in in reverse (0000 = 0x.x, 1000 = 1x.x, 0100 = 2x.x)
Ah, wonderful! Although it sounds strange it seems as if the data transmitted really is sent before a new measurement is taken. Who would design such a thing? :o
If the encoding is similar to other Bresser codes I saw, hhhh and iiii will be the checksum, ffff and gggg humidity, bbbb to eeee temperature and the second part of plus aaaa the device ID plus battery status flags.
Miq1:
I don’t think your not going to be that lucky.
It seems the left most bit of aaaa is set when the temperature is negative.
Okay I have been messing around some more and have what looks like consistent data (apart from a couple of suspect readings). The fields probably break down more or differently to what I have but the data ties up with what I have sofar. I have not tried to find battery data (assuming it has any) or figure out the CRC/Checksums. It seems the readings are transmitted base 10 but in reverse bit order.
0      0      0      1 aaaa 1 bbbb 1 cccc 1 dddd 1 eeee 1 ffff 1 gggg 1 hhhh 1 iiii 1 jjj    Temp   Hum
                              T      T      T      T             H      H                   bed c    hg
0 0000 0 0000 0 0000 1 1000 1 0001 1 0000 1 0110 1 0000 1 0111 1 0100 1 1100 1 0101 1 000   -06.0    32
0 0000 0 0000 0 0000 1 1000 1 0001 1 0000 1 0110 1 0000 1 0111 1 1010 1 1100 1 1011 1 000   -06.0    35
0 0000 0 0000 0 0000 1 1000 1 0001 1 1110 1 1100 1 0000 1 0111 1 1110 1 0010 1 0101 1 000   -03.7    47
0 0000 0 0000 0 0000 1 1000 1 0001 1 0100 1 0000 1 0000 1 0111 1 0001 1 1010 1 0100 1 000   -00.2    58
0 0000 0 0000 0 0000 1 1000 1 0000 1 1010 1 1000 1 0000 1 0111 1 1010 1 0110 1 0100 1 000    01.5    65
0 0000 0 0000 0 0000 1 1000 1 0000 1 0110 1 1100 1 0000 1 0111 1 1001 1 0110 1 1111 1 000    03.6    69
0 0000 0 0000 0 0000 1 1000 1 0000 1 0010 1 1010 1 0000 1 0111 1 0100 1 1110 1 1000 1 000    05.4    72
0 0000 0 0000 0 0000 1 1000 1 0000 1 0001 1 0110 1 0000 1 0111 1 0010 1 1110 1 0001 1 000    06.8    74
0 0000 0 0000 0 0000 1 1000 1 0000 1 0000 1 0001 1 0000 1 0111 1 1010 1 1110 1 1111 1 000    08.0    75< Suspect
0 0000 0 0000 0 0000 1 1000 1 0000 1 0000 1 1001 1 0000 1 0111 1 1010 1 1110 1 0111 1 000    09.0    75
0 0000 0 0000 0 0000 1 1000 1 0000 1 0000 1 0000 1 1000 1 0111 1 1010 1 1110 1 0110 1 000    10.0    75
0 0000 0 0000 0 0000 1 1000 1 0000 1 0001 1 0000 1 1000 1 0111 1 1010 1 1110 1 0111 1 000    10.8    75
0 0000 0 0000 0 0000 1 1000 1 0000 1 0110 1 1000 1 1000 1 0111 1 1100 1 1110 1 1110 1 000    11.6    73
0 0000 0 0000 0 0000 1 1000 1 0000 1 0010 1 0100 1 1000 1 0111 1 0100 1 1110 1 1110 1 000    12.4    72
0 0000 0 0000 0 0000 1 1000 1 0000 1 0000 1 1100 1 1000 1 0111 1 0000 1 1110 1 0000 1 000    13.0    70
0 0000 0 0000 0 0000 1 1000 1 0000 1 0110 1 1100 1 1000 1 0111 1 1001 1 0110 1 0111 1 000    13.6    69
0 0000 0 0000 0 0000 1 1000 1 0000 1 0100 1 0010 1 1000 1 0111 1 0001 1 0110 1 0011 1 000    14.2    68
0 0000 0 0000 0 0000 1 1000 1 0000 1 1100 1 1010 1 1000 1 0111 1 1010 1 0110 1 1000 1 000    14.8    66< Suspect
0 0000 0 0000 0 0000 1 1000 1 0000 1 1100 1 0110 1 1000 1 0111 1 0100 1 0110 1 1010 1 000    15.8    64< Suspect
0 0000 0 0000 0 0000 1 1000 1 0000 1 1110 1 0110 1 1000 1 0111 1 0100 1 0110 1 1000 1 000    16.7    62
0 0000 0 0000 0 0000 1 1000 1 0000 1 1000 1 1110 1 1000 1 0111 1 0000 1 0110 1 0010 1 000    17.1    60
0 0000 0 0000 0 0000 1 1000 1 0000 1 0010 1 1110 1 1000 1 0111 1 1001 1 1010 1 1101 1 000    17.4    59
0 0000 0 0000 0 0000 1 1000 1 0000 1 1110 1 1110 1 1000 1 0111 1 1001 1 1010 1 0001 1 000    17.7    59
0 0000 0 0000 0 0000 1 1000 1 0000 1 0000 1 0001 1 1000 1 0111 1 0001 1 1010 1 1000 1 000    18.0    58
0 0000 0 0000 0 0000 1 1000 1 0000 1 1100 1 0001 1 1000 1 0111 1 1110 1 1010 1 1011 1 000    18.3    57
0 0000 0 0000 0 0000 1 1000 1 0000 1 0110 1 0001 1 1000 1 0111 1 1110 1 1010 1 0001 1 000    18.6    57
0 0000 0 0000 0 0000 1 1000 1 0000 1 0001 1 0001 1 1000 1 0111 1 0110 1 1010 1 1110 1 000    18.8    56
0 0000 0 0000 0 0000 1 1000 1 0000 1 0000 1 1001 1 1000 1 0111 1 1010 1 1010 1 1011 1 000    19.0    55
0 0000 0 0000 0 0000 1 1000 1 0000 1 0100 1 1001 1 1000 1 0111 1 0010 1 1010 1 0111 1 000    19.2    54
0 0000 0 0000 0 0000 1 1000 1 0000 1 0010 1 1001 1 1000 1 0111 1 0010 1 1010 1 0001 1 000    19.4    54
0 0000 0 0000 0 0000 1 1000 1 0000 1 0110 1 1001 1 1000 1 0111 1 1100 1 1010 1 1011 1 000    19.6    53
0 0000 0 0000 0 0000 1 1000 1 0000 1 1110 1 1001 1 1000 1 0111 1 1100 1 1010 1 0011 1 000    19.7    53
0 0000 0 0000 0 0000 1 1000 1 0000 1 1001 1 1001 1 1000 1 0111 1 0100 1 1010 1 1100 1 000    19.9    52
0 0000 0 0000 0 0000 1 1000 1 0000 1 0000 1 0000 1 0100 1 0111 1 0100 1 1010 1 0000 1 000    20.0    52
0 0000 0 0000 0 0000 1 1000 1 0000 1 1000 1 0000 1 0100 1 0111 1 0100 1 1010 1 1000 1 000    20.1    52
0 0000 0 0000 0 0000 1 1000 1 0000 1 0100 1 0000 1 0100 1 0111 1 1000 1 1010 1 1000 1 000    20.2    51
0 0000 0 0000 0 0000 1 1000 1 0000 1 0010 1 0000 1 0100 1 0111 1 1000 1 1010 1 1110 1 000    20.4    51
0 0000 0 0000 0 0000 1 1000 1 0000 1 1010 1 0000 1 0100 1 0111 1 1000 1 1010 1 0110 1 000    20.5    51
0 0000 0 0000 0 0000 1 1000 1 0000 1 0110 1 0000 1 0100 1 0111 1 0000 1 1010 1 0010 1 000    20.6    50
0 0000 0 0000 0 0000 1 1000 1 0000 1 0001 1 0000 1 0100 1 0111 1 0000 1 1010 1 0101 1 000    20.8    50
0 0000 0 0000 0 0000 1 1000 1 0000 1 0001 1 0000 1 0100 1 0111 1 1001 1 0010 1 0100 1 000    20.8    49
0 0000 0 0000 0 0000 1 1000 1 0000 1 1001 1 0000 1 0100 1 0111 1 1001 1 0010 1 1100 1 000    20.9    49
0 0000 0 0000 0 0000 1 1000 1 0000 1 0000 1 1000 1 0100 1 0111 1 1001 1 0010 1 1101 1 000    21.0    49
0 0000 0 0000 0 0000 1 1000 1 0000 1 1000 1 1000 1 0100 1 0111 1 0001 1 0010 1 1101 1 000    21.1    48
Wow! I have always thought I would be good in seeing patterns, but you easily are beating me at it! :smiley:
I have a suggestion on the values - could it be there is a ‘1’ bit between every nibble? Then we would have (in reverse bit order) a plain BCD encoding. one bit in bbb is the sign, the temperature is “ffff eeee . dddd” and the humidity “hhhh gggg”:
            Head aaaa 1 bbb b 1 cccc 1 dddd 1 eeee 1 ffff 1 gggg 1 hhhh 1 iiii Tail    Temp   Hum
0000000000000001 1000 1 000 1 1 0000 1 0110 1 0000 1 0111 1 0100 1 1100 1 0101 1000   -06.0    32
0000000000000001 1000 1 000 1 1 0000 1 0110 1 0000 1 0111 1 1010 1 1100 1 1011 1000   -06.0    35
0000000000000001 1000 1 000 1 1 1110 1 1100 1 0000 1 0111 1 1110 1 0010 1 0101 1000   -03.7    47
0000000000000001 1000 1 000 1 1 0100 1 0000 1 0000 1 0111 1 0001 1 1010 1 0100 1000   -00.2    58
0000000000000001 1000 1 000 0 1 1010 1 1000 1 0000 1 0111 1 1010 1 0110 1 0100 1000    01.5    65
0000000000000001 1000 1 000 0 1 0110 1 1100 1 0000 1 0111 1 1001 1 0110 1 1111 1000    03.6    69
0000000000000001 1000 1 000 0 1 0010 1 1010 1 0000 1 0111 1 0100 1 1110 1 1000 1000    05.4    72
0000000000000001 1000 1 000 0 1 0001 1 0110 1 0000 1 0111 1 0010 1 1110 1 0001 1000    06.8    74
0000000000000001 1000 1 000 0 1 0000 1 0001 1 0000 1 0111 1 1010 1 1110 1 1111 1000    08.0    75
0000000000000001 1000 1 000 0 1 0000 1 1001 1 0000 1 0111 1 1010 1 1110 1 0111 1000    09.0    75
0000000000000001 1000 1 000 0 1 0000 1 0000 1 1000 1 0111 1 1010 1 1110 1 0110 1000    10.0    75
0000000000000001 1000 1 000 0 1 0001 1 0000 1 1000 1 0111 1 1010 1 1110 1 0111 1000    10.8    75
0000000000000001 1000 1 000 0 1 0110 1 1000 1 1000 1 0111 1 1100 1 1110 1 1110 1000    11.6    73
0000000000000001 1000 1 000 0 1 0010 1 0100 1 1000 1 0111 1 0100 1 1110 1 1110 1000    12.4    72
0000000000000001 1000 1 000 0 1 0000 1 1100 1 1000 1 0111 1 0000 1 1110 1 0000 1000    13.0    70
0000000000000001 1000 1 000 0 1 0110 1 1100 1 1000 1 0111 1 1001 1 0110 1 0111 1000    13.6    69
0000000000000001 1000 1 000 0 1 0100 1 0010 1 1000 1 0111 1 0001 1 0110 1 0011 1000    14.2    68
0000000000000001 1000 1 000 0 1 1100 1 1010 1 1000 1 0111 1 1010 1 0110 1 1000 1000    14.8    66< Suspect
0000000000000001 1000 1 000 0 1 1100 1 0110 1 1000 1 0111 1 0100 1 0110 1 1010 1000    15.8    64< Suspect
0000000000000001 1000 1 000 0 1 1110 1 0110 1 1000 1 0111 1 0100 1 0110 1 1000 1000    16.7    62
0000000000000001 1000 1 000 0 1 1000 1 1110 1 1000 1 0111 1 0000 1 0110 1 0010 1000    17.1    60
0000000000000001 1000 1 000 0 1 0010 1 1110 1 1000 1 0111 1 1001 1 1010 1 1101 1000    17.4    59
0000000000000001 1000 1 000 0 1 1110 1 1110 1 1000 1 0111 1 1001 1 1010 1 0001 1000    17.7    59
0000000000000001 1000 1 000 0 1 0000 1 0001 1 1000 1 0111 1 0001 1 1010 1 1000 1000    18.0    58
0000000000000001 1000 1 000 0 1 1100 1 0001 1 1000 1 0111 1 1110 1 1010 1 1011 1000    18.3    57
0000000000000001 1000 1 000 0 1 0110 1 0001 1 1000 1 0111 1 1110 1 1010 1 0001 1000    18.6    57
0000000000000001 1000 1 000 0 1 0001 1 0001 1 1000 1 0111 1 0110 1 1010 1 1110 1000    18.8    56
0000000000000001 1000 1 000 0 1 0000 1 1001 1 1000 1 0111 1 1010 1 1010 1 1011 1000    19.0    55
0000000000000001 1000 1 000 0 1 0100 1 1001 1 1000 1 0111 1 0010 1 1010 1 0111 1000    19.2    54
0000000000000001 1000 1 000 0 1 0010 1 1001 1 1000 1 0111 1 0010 1 1010 1 0001 1000    19.4    54
0000000000000001 1000 1 000 0 1 0110 1 1001 1 1000 1 0111 1 1100 1 1010 1 1011 1000    19.6    53
0000000000000001 1000 1 000 0 1 1110 1 1001 1 1000 1 0111 1 1100 1 1010 1 0011 1000    19.7    53
0000000000000001 1000 1 000 0 1 1001 1 1001 1 1000 1 0111 1 0100 1 1010 1 1100 1000    19.9    52
0000000000000001 1000 1 000 0 1 0000 1 0000 1 0100 1 0111 1 0100 1 1010 1 0000 1000    20.0    52
0000000000000001 1000 1 000 0 1 1000 1 0000 1 0100 1 0111 1 0100 1 1010 1 1000 1000    20.1    52
0000000000000001 1000 1 000 0 1 0100 1 0000 1 0100 1 0111 1 1000 1 1010 1 1000 1000    20.2    51
0000000000000001 1000 1 000 0 1 0010 1 0000 1 0100 1 0111 1 1000 1 1010 1 1110 1000    20.4    51
0000000000000001 1000 1 000 0 1 1010 1 0000 1 0100 1 0111 1 1000 1 1010 1 0110 1000    20.5    51
0000000000000001 1000 1 000 0 1 0110 1 0000 1 0100 1 0111 1 0000 1 1010 1 0010 1000    20.6    50
0000000000000001 1000 1 000 0 1 0001 1 0000 1 0100 1 0111 1 0000 1 1010 1 0101 1000    20.8    50
0000000000000001 1000 1 000 0 1 0001 1 0000 1 0100 1 0111 1 1001 1 0010 1 0100 1000    20.8    49
0000000000000001 1000 1 000 0 1 1001 1 0000 1 0100 1 0111 1 1001 1 0010 1 1100 1000    20.9    49
0000000000000001 1000 1 000 0 1 0000 1 1000 1 0100 1 0111 1 1001 1 0010 1 1101 1000    21.0    49
0000000000000001 1000 1 000 0 1 1000 1 1000 1 0100 1 0111 1 0001 1 0010 1 1101 1000    21.1    48
This sorts out the suspect 8.0 line as well. The two remaining suspects at least lie in the expectable range. So what if the transmission is completely decoupled from display? These could be values already measured without being displayed?
ffff is constant 0111 - battery? and iiii jumps across the table - may be the checksum nibble.
Miq1:
I have a suggestion on the values - could it be there is a '1' bit between every nibble? Then we would have (in reverse bit order) a plain BCD encoding. one bit in bbb is the sign, the temperature is "ffff eeee . dddd" and the humidity "hhhh gggg":
Sorry I have been updating my data so the one you just posted sort of matches my last offering but the header is different so you may be using an old set.
Yes the nibbles do seem to be guarded by an extra bit (0 in the sync & 1 in the data) and also looks to be BCD in reverse bit order.
aaaa, ffff & iiii are still undefined but I suspect one (aaaa) would be device or channel number. This number may change when the batteries are replaced so you could maybe try this and see what happens.
ffff is possibly battery level but to confirm you would need old batteries to test or power from a bench supply and slowly lower the voltage between readings.
iiii is most likely a checksum or CRC.
To maybe explain the header/data from #31 the second row with the upper case T & H chars is to show what column deals with temperature and humidity and the bits on the end of the row that spell out 'bed c hg' is the column the data is stored in.
b = column bbbb that is the temperature sign
e = column eeee and is the tens of degrees (BCD)
d = column dddd and is the ones of degrees (BCD)
c = column cccc and is the tenths of degree (BCD)
h = column hhhh and is the tens of humidity (BCD)
g = column gggg and is the ones of humidity (BCD)
Thanks a lot, man! That solves my riddle good enough to use the sensor further on. I will collect the aaaa, ffff and iiii data for a while to see if a pattern evolves there as well.
Thanks again!
Addition. I got a working formula to calculate the checksum iiii, that fits all data I collected so far. I do not trust it too much, though, as it contains the arbitrary constant 4 and is not using the ffff nibble at all:
crc = 4^nibble[0]^nibble[1]^nibble[2]^nibble[3]^nibble[4]^nibble[6]^nibble[7]
Nothing wrong with a starting constant but I would expect the CRC to include column ffff though.
Can you include the ffff column and end up with a different starting constant?
I am using a home-grown Genetic Programming tool to find out the formula (I am lazy :D), so I have few influence on the values it takes into consideration. The ones it found with ffff included are too ugly to be true:
dddd^eeee^gggg^bbbb^((ffff^aaaa)&(hhhh^133^cccc)) or
aaaa^bbbb^cccc^dddd^eeee^(ffff&196)^gggg^hhhh      (ffff&196 is effectively a 4)
By the way: I replaced the sensor's batteries with fresh ones today, but ffff still remained at a value of 14.
I've following log, but do not get the scheme. Am I doing something wrong at processing the am data?
Further: My packet length is 72
['1111', '1111', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '1101', '0010', '0010', '1011', '0001', '0001', '1001', '0101', '1000', '0000', '0000', '0000', '1000', '0000', '0000', '0000', '0001', '0000', '0011', '0100', '0000', '0010', '0101', '0011', '0010', '0100', '0000', '0000', '0000', '0000', '1110', '1110', '0110', '1010', '0111', '1111', '1111', '1111', '0111', '1111', '1111', '1111', '1110', '1111', '1100', '1011', '1111', '1101', '1010', '1100', '1101', '1011', '1111', '1111', '1111', '1111', '1111', '1111', '1111', '1']
['1111', '1111', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '1101', '0010', '0010', '1011', '0001', '0010', '1001', '0101', '1000', '0000', '0000', '0000', '0001', '0000', '0000', '0000', '0001', '0000', '0011', '0011', '0000', '0010', '0101', '0011', '0010', '0100', '0000', '0000', '0000', '0000', '1110', '1101', '0110', '1010', '0111', '1111', '1111', '1111', '1110', '1111', '1111', '1111', '1110', '1111', '1100', '1100', '1111', '1101', '1010', '1100', '1101', '1011', '1111', '1111', '1111', '1111', '1111', '1111', '1111', '1']
['1111', '1111', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '1101', '0010', '0010', '1011', '0001', '0001', '1001', '0101', '1000', '0000', '0000', '0000', '0001', '0000', '0000', '0000', '0001', '0000', '0011', '0100', '0000', '0010', '0101', '0011', '0010', '0100', '0000', '0000', '0000', '0000', '1110', '1110', '0110', '1010', '0111', '1111', '1111', '1111', '1110', '1111', '1111', '1111', '1110', '1111', '1100', '1011', '1111', '1101', '1010', '1100', '1101', '1011', '1111', '1111', '1111', '1111', '1111', '1111', '1111', '1']
['1111', '1111', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '0101', '1101', '0010', '0010', '1011', '0001', '0010', '1001', '0101', '1000', '0000', '0000', '0000', '1001', '0000', '0000', '0000', '0001', '0000', '0011', '0100', '0000', '0010', '0101', '0011', '0010', '0100', '0000', '0000', '0000', '0000', '1110', '1101', '0110', '1010', '0111', '1111', '1111', '1111', '0110', '1111', '1111', '1111', '1110', '1111', '1100', '1011', '1111', '1101', '1010', '1100', '1101', '1011', '1111', '1111', '1111', '1111', '1111', '1111', '1111', '1']
['1111', '1111', '1010', '1010', '1010', '1010', '1010', '1010', '1010', '1010', '1010', '1010', '1110', '1001', '0001', '0101', '1000', '1000', '0100', '1010', '1100', '0000', '0000', '0000', '0000', '0000', '0000', '0000', '0000', '1000', '0001', '1010', '0000', '0001', '0010', '1001', '1001', '0010', '0000', '0000', '0000', '0000', '0111', '0111', '1011', '0101', '0011', '1111', '1111', '1111', '1111', '1111', '1111', '1111', '1110', '1111', '1100', '1011', '1111', '1101', '1010', '1100', '1101', '1011', '1111', '1111', '1111', '1111', '1111', '1111', '1111', '1']
['1111', '1111', '1010', '1010', '1010', '1010', '1010', '1010', '1010', '1010', '1010', '1010', '1110', '1001', '0001', '0101', '1000', '1000', '1100', '1010', '1100', '0000', '0000', '0000', '0000', '0000', '0000', '0000', '0000', '1000', '0001', '1001', '1000', '0001', '0010', '1001', '1001', '0010', '0000', '0000', '0000', '0000', '0111', '0111', '0011', '0101', '0011', '1111', '1111', '1111', '1111', '1111', '1111', '1111', '1110', '1111', '1100', '1100', '1111', '1101', '1010', '1100', '1101', '1011', '1111', '1111', '1111', '1111', '1111', '1111', '1111', '1']
