I bought an arduino duo yesterday and was looking forward to playing around with it.
I did the blink led, arduino worked fine.
I had bought some ATMEGA328P-PU and wanted to use the arduino as an ISP, that's where things started going wrong.
Probably the arduino didnt like me taking the chip out a few times. I uploaded this atmega chip detector to try to identify the chip I was trying to flash with the atmega board config with 8mhz internal clock, but it never worked right.
Eventually my arduino broke. Classic errors:
avrdude: stk500_getsync(): not in sync: resp=0x00
The L led is on permanently, and pressing the reset button doesn't make that LED go off.
According to the internet, it's broken. However my computer still detectcs it as a usb to serial bridge. Is there anything I can use this for or should I just throw it in the trash by now?
Troubleshoot it.
Are the 5V and 3V3 still good?
It seems like the FTDI/comms IC is still OK.
You can't/shouldn't pull/place the microcontroller with the Arduino powered.
If you put it in backward that'd biff it.
It's probably OK, but you need a bootloaded 328 or an ICSP programmer to bootload it with.
Did you accidentally fold-under/bend a pin on insertion? Fyi I personally never advise people to use the
arduino as an isp... especially someone new. Really, just invest in a decent programmer, like usbtinyisp.
